There’s a repeat filter under Settings -> Input -> Peripherals
If you’re referring to long press support however, I don’t believe this is part of the CEC standard.
@sam_nazarko
Another quick question on CEC mate:
Ive set it up so that my TV goes into standby when the Kodi screensaver activates, but it won’t wake up again when I deactivate the screensaver, im testing by issuing commands from the iOS Kodi remote, or by remotely starting a TV channel from a terminal.
If I restart the mediacenter service or reboot the Vero remotely from terminal, it does then successfully wake the TV, which I presume is also being done via CEC.
Is there anything im missing here?
Edit: Its working now, no idea why it wasn’t before, I had a coffee and went for my morning poo and its behaving how I want.
