CEC TV Remote stopped working
Hi, suddenly I cannot control the Vero 4k with my TV remote anymore.
Coincidentally my TV received a firmware update while I was at work and when I got home I noticed this problem.
I did a factory reset of the TV, but that didn’t help. The TV remote is still able to change the receiver volume and the CEC on off functions work, but no arrow or ok functions.
To test further I disconnected the HDMI cable from the Vero and connected back to my Shield TV and in that case the remote can control the Shield without any issue, so CEC commands from the TV seem ok.
I rebooted the Vero box about 10 times and on one of these times, the CEC control worked…
I even set back the CEC settings in kodi to default, but no luck.
Hopefully you guys can help me figure out what’s wrong.
Here’s a log:
http://paste.osmc.tv/uzekamabun
Try powering down everything at the mains for five minutes.
Thanks Sam, unfortunately it didn’t help…
I tried many power up sequences (receiver last, tv last, vero last) and even connecting the TV directly to the Vero without receiver. I just can’t get it to work anymore. It worked perfectly out of the box until today…
Any ideas?
  • Some more info: The TV sees “Kodi” (Kodi is listed in the list of CEC devices connected)
  • Connected the Vero directly to the TV using a different (trusted) HDMI cable. no change.
  • I searched through the forum and I issued this command (twice, because I got an error the first time):
    osmc@osmc:~$ echo scan | cec-client -s -d 1
    opening a connection to the CEC adapter…
    requesting CEC bus information …
    ERROR: [ 21160] failed to request the physical address
    CEC bus information
    device #0: TV
    address: 0.0.0.0
    active source: no
    vendor: Unknown
    osd string: TV
    CEC version: unknown
    power status: on
    language: eng
    device #1: Recorder 1
    address: 1.7.0.0
    active source: no
    vendor: Pulse Eight
    osd string: CECTester
    CEC version: 1.4
    power status: on
    language: eng
    device #5: Audio
    address: f.f.f.f
    active source: no
    vendor: Denon
    osd string: AVR-X3400H
    power status: on
    language: ???
    currently active source: unknown (-1)
    CEC bus information
    device #0: TV
    address: 0.0.0.0
    active source: no
    vendor: Unknown
    osd string: TV
    CEC version: 1.4
    power status: on
    language: ???
    address: 1.7.0.0
    active source: no
    vendor: Pulse Eight
    CEC version: 1.4
    power status: on
    language: eng
    device #5: Audio
    address: 1.0.0.0
    active source: no
    vendor: Unknown
    power status: on
    language: ???
Okay – let’s think about what might have changed.
Have recent devices been added / powered recently?
Does CEC work if HDMI is temporarily ran to the TV directly?
Thanks Sam.
Devices are the same, but VIZIO updated the firmware of the TV yesterday. The problems started at the same time. This is suspicious because they mention some CEC changes in their release notes:
Update the Cast Shell to 1.27
HDR Certification for 2016 P and 2017 M and P series
Fix for casting DirecTV now app 30 second loop problem
Alexa Performance improvements
p65-e1 white line issue fix
CEC Auto Naming
Correction to blue screen when casting Spotify
General/overall system improvements.
Having said that, Denon and Shield TV continued to be CEC controlled without issues after the firmware update. Maybe some subtle changes that affect only some hardware…
No, I can’t make CEC control to work at all, excluding the receiver from the chain, using different shorter cables, etc… Nothing seem to work. Only once yesterday after a reboot it worked, but I wasn’t able to reproduce that again.
I’m new to OSMC, so I’m not sure when updates are released. Was there anything updated in the last 48 hours?
No changes.
I wonder if we need to change the role of the Vero 4K for you. Some information:
See
Changing the device type via peripherals.xml might work for you.
It’s alive! Thanks for the suggestions. Actually, changing values in this file:
/usr/share/kodi/system/peripherals.xml
didn’t do anything. So I went ahead and make a change to:
.kodi/userdata/peripheral_data/cec_CEC_Adapter.xml
I changed device type from “1” to “4” and the remote started working immediately.
Hopefully this is a stable fix!
Yes – this adjustment will be persistent. If you ever reinstall OSMC however you’ll need to make these changes again.
