Hi all,
I’m experiencing a problem with certain video files were the video freezes for a second or two and the audio continues. The video then continues without problems and in sync.
So far this hasn’t happend with HD (720p and 1080p) videos and neither with 4k videos. It has only happened with lower res videos. At the end of this post you can find the media info of one of these files.
TS I’ve done so far:
turn off / on whitelist
turn off / on allow 3:2 pulldown refresh rates
turn off / on allow double refresh rates
Play file locally from USB HDD
Non if this worked, but turning off hardware acceleration did the trick. I’m not sure if turning off hardware acceleration should be the solution.
Here if a log of when the freezing occurs. I stopped the video immediately after it happened.
General
Complete name : K:\TV Shows K\Adventure Time\Season 1\Adventure Time S01E17 When Wedding Bells Thaw.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/iso2/avc1/mp41)
File size : 27.0 MiB
Duration : 11 min 53 s
Overall bit rate : 318 kb/s
Frame rate : 23.976 FPS
Movie name : Adventure Time S01E17 When Wedding Bells Thaw
Encoded date : 2017-03-24 13:53:43 UTC
Tagged date : 2017-03-24 13:53:43 UTC
Writing application : HandBrake 0.10.5 2016021100
Video
Format : AVC
Format profile : Main@L4
Format settings : CABAC / 16 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 16 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 246 kb/s
Width : 640 pixels
Height : 360 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Minimum frame rate : 23.974 FPS
Maximum frame rate : 23.981 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.044
Stream size : 20.9 MiB (77%)
Writing library : x264 core 142 r2479 dd79a61
Encoding settings : cabac=1 / ref=16 / deblock=1:1:1 / analyse=0x1:0x131 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=28.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:0.60
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Menus : 3
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate mode : Variable
Bit rate : 66.2 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 5.58 MiB (21%)
Title : Stereo / Stereo
Language : English
Default : Yes
Alternate group : 1
Menus : 3
Menu
Format : Timed Text
Codec ID : text
Duration : 11 min 52 s
Language : English
Bit rate mode : CBR
Menu For : 1,2
Duration_FirstFrame : -628169
Duration_LastFrame : -620787
00:00:00.000 : Chapter 1
00:00:25.609 : Chapter 2
00:11:19.387 : Chapter 3
Bit rate mode : Constant
