Hello I bought the vero 4k+. Im happy with it but i have a problem, my tv is a lg from 2016 fullhd. My tv cant output corretly YCbCr 4:2:2 because cause a lot of color banding. In my blu ray player output YCbCr 4:4:4 and the image looks good. How can i put the vero 4k+ to output YCbCr 4:4:4 like my blu ray player.
It will output 444 by default. Make sure Force 422 colour subsampling is OFF in Settings->System->Display.
Its off and it still output YCbCr 4:2:2
reproduce the issue
upload the log set (all configs and logs!) either using the
Also - what makes you think it is outputting 422? Does the TV give you this information?
Your TV does not seem to support deep colour (10-bit video) which is surprising for a 2016 model. Do you see the same issue if you plug Vero into the TV direct?
It is also surprising that 422 shows banding while 444 (8-bit) does not. You can force Vero to output 8 bits using the commandline via ssh and typing:
echo 4448bitnow | sudo tee /sys/class/amhdmitx/amhdmitx0/attr
If that works, we can tell you how to make that setting permanent (ie survive a re-boot).
How i put the commnadlines??
Please see the folowing wiki…
It works how i can do it permanently??
type
sudo nano /etc/rc.local
that starts an editor on the file rc.local
type this just above the line where it says exit 0
echo 4448bit > /sys/class/amhdmitx/amhdmitx0/attr
save the file (ctrl-X). Re-boot and check that it still works.
it works thanks so much. It will be ok if you can switch without using the console.
Again thanks
We could do that, but your situation is very rare.
