I’ve upgraded Vero 4k Hard Drive from 1TB 2.5 to a 4TB 2.5 Hard Drive, powered from a hub.
I cloned the old drive to make things simple, everything has worked fine, but the original Drive was named “1TB external”
Is there an easy way to change my new drive name to something like “4TB external” without messing up my scanned library? I.E. “My Movies and Music are now stored on this Drive, don’t rescan anything, just change the location”
Have looked on Vero & Kodi forums, but not found anything, any help in the right direction would be great.
Or just an answer saying you cant do that easily .
I can rename it on Windows easy enough, but then my films and music aren’t available on the Vero.
If I change it back again, then they are available again.
Since it is not entirely clear what all has been done with your sources and library let me just offer this. Fresh install you add a source called “moviesource” at path /mnt/x/movies/ and set a scraper on “moviesource” to movies and TMDB. You then update the library which stores an absolute path for all the media in that path. An entry for movie.mkv is stored in the database as something like /mnt/x/movies/moviename/movie.mkv and no longer has anything to do with the source. If /mnt/x/ changes to /mnt/y/ then everything from that path will no longer work in your library. It is at this point you have two choices. The preferred option is to change /mnt/y/ back to /mnt/x/ and then everything is golden again. The second viable option is to do a path substitution such that when Kodi goes looking for /mnt/x/ it automatically redirects to use /mnt/y/ instead. Again everything is golden (as long as another mnt/x/ doesn’t show up and leave you scratching your head on why it doesn’t work )
Normally where people get into trouble is when they change an existing source to match the path that changed. In this example if you update “moviesource” to point to /mnt/y/ then update your library now you have two entries for movie, with one of them working and the other not, because they are stored according to what file path is set in the source when it was scraped. At this point people commonly do all kinds of things to try to fix the mess that is left over. If you can understand the above, and know what you did, you may be able to find a path to back yourself out.
And if you want an easy way to see what file path is being referenced for any given library item just bring up an information window and highlight the “refresh” option. I think most skins will show the file path at that point.
Either rename your new drive to match the old name or do a path substitution to redirect from /media/1TB external/ to /media/4TB Seagate Red/ and call it job done. Instructions on how to implement a path substitution are spelled out in great detail in the how-to that is linked to above.
