In 99.9% I want to shut down my Raspberry. Can I change the order of entries in the shutsown menu (after I press Ctrl+s), so the Shutdown will be on the first position.
If I accidental press Return on first entry, my GUI freeze and I’m only can shutdown with a SSH connection - or power off :(.
Thanks! I clean out my addons and now it works with a reboot.
But there is now answer to the question, if it is possible to reorder this menu, so that the “shutdown” entry is at the first position. Or is it possible to set the shutdown to a shortcut like Ctrl+F12?
