Battery’s not swollen. It came with the Vero if I am not mistaken. Tried another one, same deal. And as CR2032 it is 3.2mm thick. It’s not a user error, I am totally able to put a battery in…
But it’s not a biggie. Remote works fine. Just one of the small things…
If I close the battery cover without the battery it is flush like in your picture, one side a tad higher though, but that was not the case initially. Happened because of the pressure since 2.5 months.
Edit: Tried a CR2025 I found in my desk drawer. Thinner and just 165 mAh instead of 225mAh. Naturally is a tad too thin. But putting a piece of folded paper under it does the trick. The one side still portrudes a bit more, but nothing dramatic like before - more in line with your picture and basically same deal as without a battery. Looks like it was manufactured with an imaginary CR2028 or so in mind.
Yeah get it, more pressure for “new” regulations without any real redesign for a better cover that also holds on the sides, you know like the covers that really need to slide in place or have more than just on notch. Yeah, cheapo Chinese stuff, I know the drill. But have seen far worse remotes that came with devices I wouldn’t even touch.
Always guess I run with CR2025s and a piece of paper then from now on and fiddle a bit with the inside to have more of a dampened sound.
Regarding eventlircd:
Yeah, seems pretty straight forward, just a few lines with some hardcoded values… I probably change it and add a repeat-filter-cfg or some command line parameters here to tweak it so I can adjust it easily.
Need to think what makes sense to have an initial delay before repeating, then the initial repeat speed, maximum repeat speeds in case it should accelerate further and make it linear or exponential. Maybe better to point it at some file for easier user configuration. Might look at it next weekend or the weekend afterwards.
I’ll let you know when I made the changes, so you can take a look at them.
Anyway, thanks for the great support. As always worth the extra surcharge on the Vero 4K, which is still the best small footprint device for media playback I ever owned.
