Ive just bought a Vero V and would like to change one function on the remote that was shipped with it…
I have tried changing the mapping with the ‘keymap editor’ add-on - But the window that I want to add is not in the list - So I need to do this manualy
Id like to change that menu button on the Vero V remote to ‘ActivateWindow(1101)’
Which opens the ‘cog’ menu during playback that contains Video, Audio and Subtitle Setting menus
My question is, what file contains the mapping for the OEM Vero V remote?
And where is it located in the Vero device?
Except I’m pretty sure that isn’t going to work and I don’t think there is a way to directly keymap what you want without modifying the skin itself. What you can do without an issue is keymap directly to the locations that menu is pointing to. This is already done by default with menu opening the video settings, holding down menu bringing up the audio settings, and holding down stop bringing up the subtitle settings. You can of course switch around what buttons do what using that file Sam linked to as a guide.
