Trying to change to port 80 from the default (8080) and it fails to take. In the logs I just see:
ERROR: Cannot start Web Server on port 80
Running netstat doesn’t show anything running on port 80 - is there any reason why this shouldn’t work?
I have the same issue and had given up, but I’ll keep an eye out here to see if anyone has a solution.
Providing a debug log would likely give us a clue what is going on so that a fix can be implemented.
The kodi debug log doesn’t really offer much. Is there another log that might help?
16:11:56 T:3023986688 NOTICE: Webserver: Stopping…
16:11:56 T:3023986688 NOTICE: WebServer: Stopped the webserver
16:11:56 T:3023986688 NOTICE: Webserver: Stopped…
16:11:56 T:3023986688 DEBUG: CZeroconfAvahi::doRemoveService named: servers.webserver
16:11:56 T:3023986688 DEBUG: CZeroconfAvahi::doRemoveService named: servers.jsonrpc-http
16:11:56 T:3023986688 ERROR: Cannot start Web Server on port 80
16:11:56 T:3023986688 DEBUG: ------ Window Init (DialogOK.xml) ------
16:11:56 T:3023986688 INFO: Loading skin file: DialogOK.xml, load type: KEEP_IN_MEMORY
16:11:56 T:2928669728 DEBUG: PushCecKeypress - received key a6 duration 74
Pastebin this would be great.
Here you go:
http://paste.osmc.io/jubefufipa
I just tried to change the port at around 16:20 and there’s nothing in this log either…
Probably issue with setpcap.
Will check it out
This is now fixed and will be available in the next release:
S
Super-speedy turnaround! Thanks Sam!
