Running OSMC on an RPi2 and after some tweaking I really like it
On thing though is the logos. In all other solutions like openelec/xbian etc when you go into live-tv it shows the logo of the channel. In OSMC its only a padlock on almost all channels, just a few with logos that doesnât have any encryption.
You didnât say whether the icons were correct with Confluence. It would be helpful to know this because if this is the case we have a bug to fix in the OSMC skin.
I donât use tvheadend anymore so can not say whats wrong but I clearly know that it was working when I used it.
But maybe @BobCratchett can take a look when he has time
Yes, itâs a Tvheadend backend with DVB-S. Well the thing is, the skin is aware of that, so itâs more of a âbad featureâ than a bug, I mean that it must have been intentionally written to show that padlock icon right? Even the original skin that this OSMC skin is based off (Conq) had the same functionality.
It well could be intentionally written that way but that is just a wild guess. I have mentioned the OSMC skin developer in my last post, letâs see when he finds time to take a look into it.
OK, had time to look into this, but not to fix it yet. Long story short, if the channel is encrypted (ListItem.IsEncrypted), we show the padlock image, if not we show the channel logo. As has been pointed out, the skin is a direct descendant of the Conq skin and this is something weâve inherited from that - Iâd take a guess that the original author didnât expect encrypted channels to actually be playable via Kodi. If thatâs not the case - and do please confirm - then Iâll add it to the to-do list to look at a better way to highlight encrypted channels than replacing the whole logo.
Well, If it was me, I would simply remove this feature and show the normal channel logos. Because the PVR backend takes care of this stuff. You are in charge of what channels you add or remove from list. If you donât have a cable card for example and youâre watching only FTA, then you will not add channels you canât watch to your channel list.
In my case for example, I have a satellite dish, decrypting card from my satellite provider and backend (Tvheadend) does all this stuff, Kodi is just a video player, it receives video stream, Kodi never handles decrypting, tuning, scanning, handling of tuners, thats why we use the Frontend-Backend scheme.
So from my point of view, I would just show the channel logos to all of the channels. Thatâs even default behavior in Estuary, Confluence - the default Kodi skins and basically every other skin I tried except Conq
I had the same problem as the thread creator, so no fix is published yet, so I fixed it myself and now I would like to share my solution and would provide the fixed skin. I hope this is fine for the osmc team
The fix is very simple
Remove this line in the Variables.xml in the 16x9 folder.
Although a long time ago, this has now been fixed⌠Since Iâve taken over development of the skin, I havenât got aware of this request/issue, but @Donderstraaltje has made me aware of this on GitHub recently. See this commit for the fix which will be available with the next OSMC update: Add option to show lock icon for encrypted PVR channels
This change makes it the default behaviour to show icons of encrypted PVR channel icons. The setting gives the option return to the old default behaviour - showing a lock icon instead of the channel icon.
