will it be a installable hotfix? or a full system image?
You will need to install it via SSH.
ok!
hey @sam_nazarko, any progress with that test build?
Not yet. I’ll let you know when it is ready.
ok, thank you
@sam_nazarko Will this come after the 18.4 final build?
No - before.
thank you sir
Thanks for your patience here. I’ve made two changes:
- One to support chapter seeking without depending on key frames
- One is a backport of some TrueHD fixes, which fixes some crashes which can occur when seeking and TrueHD passthrough is not enabled.
To test this update:
- Login via the command line
- Edit the file
/etc/apt/sources.list - Add the following line:
deb http://apt.osmc.tv stretch-devel main - Run the following commands to update:
sudo apt-get update && sudo apt-get dist-upgrade && reboot - Your system should have have received the update.
I was having this issue as well, will install the patch.
Looking forward to your feedback.
installed, and ran a few quick tests, chapter skip works perfectly now!
TrueHD Passthrough is Enabled on my system so i can not comment there
Glad to hear this. Thanks for testing. I’ll make this part of today’s update.
I can confirm, works very good now.
Thanks for confirming
