Hi Forum, hi chillbo,
I am a long-time user of the Transparency! skin for Kodi. I like the way this skin shows fanart, but unfortunately the author will not update his skin for Kodi 19 version.
So, I make myself familiar with the original OSMC skin and I start to like it. As I am working though the different settings, I have one question regarding the background opacity.
There are four options to set the background opacity to: low, med, high, highest. Even when I set the background opacity to low, the fanart is still not clearly visible, it still looks foggy.
Is there a possibility to adjust the background opacity to none in order to have a clear fanart?
Thanks.
