Hello,
I just discovered some problems with playing back HEVC encoded anime Ghibli Collection movies.
They are playing choppy right from the start, and when I hit OK button (to display player controls and progressbar) it does frequently like if its seeking.
I have vero4k with latest OSMC.
But, when I disable hw acceleration, it plays back OK…of course until CPU gets to 100%.
Here is mediainfo:
Video
Format : HEVC
Format profile : Main@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 12 min
Bit rate : 1 234 kb/s
Width : 1 920 pixels
Height : 1 036 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.026
Stream size : 637 MiB (92%)
Default : Yes
Forced : No
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Bit rate : 101 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Delay relative to video : 20 ms
Stream size : 52.2 MiB (8%)
Language : Japanese
Default : Yes
Forced : No
I have more files like this and all of them behave the same. Any other HEVC encoded movie plays back OK. Have anyone encounter similar behaviour? Thanks.
