Choppy AVI playback on RPI2
So I recently upgraded from a RPI B running RaspBMC, to a RPI2 running OSMC, and now a lot of the avi(Xvid) playback is choppy, it wasnt choppy on my RPI B running RaspBMC.
Here is the exiftool output on one of the files.
exiftool S05E15\ -\ A\ Funeral\ Brings\ George.avi
ExifTool Version Number         : 9.74
File Name                       : S05E15 - A Funeral Brings George.avi
Directory                       : .
File Size                       : 175 MB
File Modification Date/Time     : 2015:08:12 18:36:51-04:00
File Access Date/Time           : 2015:08:25 09:17:14-04:00
File Inode Change Date/Time     : 2015:08:12 18:36:51-04:00
File Permissions                : rw-r--r--
File Type                       : AVI
MIME Type                       : video/x-msvideo
Frame Rate                      : 23.976
Max Data Rate                   : 0 kB/s
Frame Count                     : 30871
Stream Count                    : 2
Stream Type                     : Video
Video Codec                     : xvid
Video Frame Rate                : 23.976
Video Frame Count               : 30871
Quality                         : 10000
Sample Size                     : Variable
Image Width                     : 624
Image Height                    : 352
Planes                          : 1
Bit Depth                       : 12
Compression                     : XVID
Image Length                    : 1317888
Pixels Per Meter X              : 0
Pixels Per Meter Y              : 0
Num Colors                      : Use BitDepth
Num Important Colors            : All
Audio Codec                     :
Audio Sample Rate               : 41.67
Audio Sample Count              : 53648
Encoding                        : MP3
Num Channels                    : 2
Sample Rate                     : 48000
Avg Bytes Per Sec               : 15266
Bits Per Sample                 : 0
Total Frame Count               : 30871
Software                        : VirtualDub
Duration                        : 0:21:27
Image Size                      : 624x352
Can you provide a sample file that has the problem?
legally I can not. I will do some digging and see if I can find a small sample file that does this.
Media snippet used for troubleshooting of hardware is covered under “fair use”. Just create a small ~100mb sample that exhibits the issue.
