Hi there,
is there a possibility to integrate Chromium for play Amazon Prime in OSMC Kodi ?
Thanks for an answer.
Not directly, but there is a thread already in the How To section of the forum on how to install a separate X environment running Chromium. You can use the magnifying glass in the top right of the page to search for “Chromium” and you will find it.
