I have a Rasberrypi 2 with a cirrus audio card.
With OSMC the touchscreen is working fine, but I have only output on the rasberrypi.
The audio card is not working.
How can I get my Cirrus audio card working?
Hugo50
Hugo50
Don’t know much about that card. Is it USB or I2S?
It is a Cirrus Logic audio Card, attached to the raspberrypi with the GPIO Connection
Disable LIRC GPIO IR remote in Pi Config
