I have cirrus logic audio card on my rpi and it worked. today I updated the system and it stopped working. the error in the dmesg is:
arizona spi0.1: Failed to request DCVDD: -517
it seems that there is no arizona-ldo1 module compiled in the latest kernel while in previous kernel this module was compiled.
Add the following line: deb http://apt.osmc.tv stretch-devel main
