I’ve some files like
10025-f669cb20.fi (*.fi)
in the .kodi/temp folder.
Inside it’s
A^N^@^@^@FranceTV Pluzz^@^@^@^@ ^@^@^@E^@^@^@x^@^@^@t^@^@^@e^@^@^@n^@^@^@s^@^@^@i^@^@^@o^@^@^@n^@^@^@s^@^@^@^@^@^@^@^@^@^@^@^@^A^@^@^@^N^@^@^@plugincategory^C^@^@^@^N$ ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^A^@^@^@^A^@^@^@^@^@^@^@^A^@^@^@^@^@^@^@(^B
I think I can delete this files ??
Merci
Michael
Yes you can delete files in this directory
It is likely an add-on causing this
Yes, it’s cached fileinfo data. If they are deleted they will be recreated (if needed again).
