I’m experiencing clipped highlights on my Vero 4K+. Anything above 235 white clips to pure white, losing all detail in bright areas.
Setup:
Vero 4K+ → Onkyo TX-SR705 → BenQ W2000 projector (HDMI)
Also tested Vero directly to BenQ (same issue)
PS4 connected to same BenQ looks perfect—no clipping
What I’ve tried:
Kodi display settings: Limited range enabled
BenQ HDMI Range: Video (Limited) - also tried Auto and PC
Disabled all hardware acceleration in Kodi
Default Estuary skin
Sync playback to display: off
Bypassed the Onkyo entirely (no change)
Resolution whitelist settings are correct
Key observations:
When Kodi dims the screen (inactivity/screensaver), the crushed highlights recover and I can see detail in bright areas. As soon as the screen returns to normal brightness, highlights crush again.
Using AVS HD 709 test patterns, I found that lowering the per-video brightness from 50 to 16 brings back all test bars from 235-254. However, this severely crushes blacks—so I’m trading one problem for another.
Adjusting contrast alone doesn’t fix it without affecting the other end of the range.
Conclusion:
This suggests the Vero 4K+ is outputting video with an incorrect gamma curve or level mapping—the signal appears to be expanded or shifted incorrectly. I shouldn’t need to drop brightness by 34 points to get correct white levels. It used to be OK, this is a fairly recent development.
Questions:
Is there a known fix for incorrect output levels on the Vero 4K+?
Is there a way to force correct limited range output via SSH?
