Clone Vero 5
I’m looking to clone my settings from one Vero5 to another, what is the best way to do this please?
Apologies if this is already posted somewhere.
You can do that from My OSMC → Updates → Backups: here you can select what you want to backup and where you want the backup to be saved.
And you can run the backup and restore from My OSMC → Updates → Manual Controls
Unless you want to do a root filesystem clone (i.e. you’ve customised the device significantly), what @thansen_dk suggests will suffice.
Thank you both!
