In order to move to an RPi3B system I have tried to make a clone SDcard on an RPi2B running the latest version of OSMC with the rpi-clone program available via git.
I use the following command after first:
- Shutting down Kodi:
systemctl stop mediacenter - Plugging in the USB carrier of the clone target SDcard
- Unmounting the automounted partitions on sda (I am using a SDcard used on a RPi before)
- Using fdisk to remove the partitions on /dev/sda
Then I call rpi-clone like this: sudo rpi-clone -f /dev/sda
Now there are some user input acknowledging allowing reformatting the target drive etc.
After this the process starts and seems to go normally for 8 minutes or so.
But then I get a bunch of errors concerning the /boot partition…
What does this mean for the functioning of the cloned backup SDcard?
Sample of the output (I cut away a lot of similar looking lines):
Syncing file systems (can take a long time)
Syncing mounted partitions:
Mounting /dev/sda2 on /mnt/clone
=> rsync // /mnt/clone with-root-excludes ...
Mounting /dev/sda1 on /mnt/clone/boot
=> rsync /boot/ /mnt/clone/boot ...rsync: chown "/mnt/clone/boot/." failed: Operation not permitted (1)
rsync: readdir("/mnt/clone/boot/."): Input/output error (5)
rsync: chown "/mnt/clone/boot/bcm2708-rpi-b-plus.dtb" failed: Operation not permitted (1)
rsync: chown "/mnt/clone/boot/bcm2708-rpi-b-rev1.dtb" failed: Operation not permitted (1)
rsync: chown "/mnt/clone/boot/bcm2708-rpi-b.dtb" failed: Operation not permitted (1)
rsync: chown "/mnt/clone/boot/bootcode.bin" failed: Operation not permitted (1)
rsync: chown "/mnt/clone/boot/config-user.txt" failed: Operation not permitted (1)
rsync: chown "/mnt/clone/boot/dtb-5.10.32-2-osmc" failed: Operation not permitted (1)
IO error encountered -- skipping file deletion
rsync: chown "/mnt/clone/boot/dtb-5.10.32-2-osmc/overlays" failed: Operation not permitted (1)
rsync: chown "/mnt/clone/boot/overlays" failed: Operation not permitted (1)
rsync: mkstemp "/mnt/clone/boot/.LICENCE.broadcom.QLeAbe" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/.System.map-5.10.32-2-osmc.WM1Rim" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/.bcm2837-rpi-3-b.dtb.i0JmtF" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/.bcm2837-rpi-cm3-io3.dtb.TrDKfT" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/.cmdline.txt.sqAvH6" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/.config-5.10.32-2-osmc.vkPM4i" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/.config.txt.0OjSQv" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/.fixup4x.dat.pYWyFI" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/.fixup_x.dat.ONlTDX" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/.install.log.1qf1Cc" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/.kernel.img.K6VpEr" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/.start4x.elf.taJXdj" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/.start_x.elf.SJ9imi" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/.vmlinuz-5.10.32-2-osmc.wpFdFo" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/dtb-5.10.32-2-osmc/.bcm2708-rpi-b-plus.dtb.AoYjO4" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/dtb-5.10.32-2-osmc/.bcm2708-rpi-b-rev1.dtb.4KEzzM" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/dtb-5.10.32-2-osmc/.bcm2708-rpi-b.dtb.aHh9lu" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/dtb-5.10.32-2-osmc/overlays/.vga666.dtbo.yJ0IV6" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/dtb-5.10.32-2-osmc/overlays/.w1-gpio-pullup.dtbo.eOSA66" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/dtb-5.10.32-2-osmc/overlays/.w1-gpio.dtbo.ShU2g7" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/dtb-5.10.32-2-osmc/overlays/.w5500.dtbo.Wkp0q7" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/dtb-5.10.32-2-osmc/overlays/.wittypi.dtbo.OzZ3E7" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/dtb-5.10.32-2-osmc/overlays/.wm8960-soundcard.dtbo.SUVuR7" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/overlays/.README.6WFx37" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/overlays/.act-led.dtbo.jb3sRv" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/overlays/.adafruit18.dtbo.kTqrDT" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/overlays/.adau1977-adc.dtbo.xh3Jsh" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/overlays/.adau7002-simple.dtbo.EQkMkF" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/overlays/.w5500.dtbo.34UOPr" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/overlays/.wittypi.dtbo.ovyUV5" failed: Read-only file system (30)
rsync: mkstemp "/mnt/clone/boot/overlays/.wm8960-soundcard.dtbo.NXDs1J" failed: Read-only file system (30)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1207) [sender=3.1.3]
Done with clone to /dev/sda
Start - 23:42:51 End - 23:52:01 Elapsed Time - 9:10
Cloned partitions are mounted on /mnt/clone for inspection or customizing.
