Hello,
I’m a new owner of a Raspberry Pi 3 witch I used to install OSMC.
Everything was okay until this afternoon when it came to heat a lot without any reason.
Let me explain, I used the raspberry Pi to look at some 480p live for few hours, without any truble (I don’t have any Heatsink), I didn’t had any heat.
But today when I woke up my Raspberry Pi, she started to make an electrical sound and show a lightning. At this moment I just cut out the power and I felt some heat from the Raspberry
I wait a little bit, and I chose to power my Raspberry with my Samsung Charger (5V- 2Amp) instead of my pull down, witch can pull up to 4A with my 12V-6A power.
But during the boot, my Rasp was already getting hot, and when it got to the main menu, it was showing the thermometer so I turned off my Rasp and tried to reinstall a fresh OSMC on it, but I had the same problem at the moment it booted up.
Do you have any idea for my problem ?
Thanks a lot
Jean-Baptiste
(Sorry if there is some problems in my writing, I’m not English)
