Since several days I have problems with the colors of OSMC on my RPI4, it happened with the november or december update I don’t know.
The colors are too bright and when the resolution change when I play a video (this option was turned off before the update) the colors are too dark and stay dark even after I stop the video. I read a few topics on HDR but my TV is not HDR so I don’t know what happened during the update.
I tried with another SD card and reinstall the august update, the colors are normal.
reproduce the issue
Actually after a few tests, the colors after changing the frame rate is the same than before (the same I had in the august version), but I have to manually go in the menu to change the rate to have the good colors at each reboot.
It’s only at the start of OSMC and I just noticed after a few tests that this problem doesn’t happen with the other HDMI port of the RPI4. So now I’m using the other HDMI port (the closest to the power cable) and it seems working but I don’t know why.
I can confirm. I have the exact same problem. When the Raspberry Pi is connected to the HDMI 1 port, all colors are washed out when Kodi starts during boot-up. If I change the refresh rate or resolution, it seems that it fixes itself. This problem doesn’t occur on the HDMI 0 port.
Interestingly enough, it seems that when I power it on, the OSMC splash screen has the correct colors, but when Kodi starts, it switches to the washed out version. If I go to Power > Exit and close Kodi, as OSMC tries to restart it again, I noticed that this time, the OSMC splash screen is also washed out.
Not sure what the cause of the problem is, but is seems that it happens when Kodi starts.
P.S.: after doing the resolution/refresh rate quick fix, the colors don’t change when restarting Kodi. It seems it only happens once when booting up
