have updated config.txt via nano.
now osmc is not reading config.txt any more.
How to solve this issue?
Is there a initial config.txt to be used ?
Thanks T
Thanks T
I think the easiest is to revert in nano the changes you have made.
I did some changes, do not exactly realize which one caused the problem?
are comments a problem?
sequenz of command?
will try some
thanks
run grab-logs -p and share the URL than we can give advice
Hi Thanks
please see here:
https://paste.osmc.tv/xitatalila
Well as a start I would remove the characters you have around the = in this line
hdmi_ignore_edid_audio = 1
ok will try
thanks
done, does not help
still unable to open config dialog in myosmc
Ok, I copied your contents into a new config.txt on my system and was able to open it in MyOSMC.
So suggest you copy and paste the contents of mine into a clean one on your system and try.
If you still have an issue I suggest to enable debug logging and upload logs after you try to edit it vua MyOSMC.
Here is mine working with your content. You can directly copy it on your system.
sudo wget -O /boot/config.txt https://paste.osmc.tv/ukawenecob
Check the contents afterwards with cat /boot/config.txt
thanks for your support
still not working:
https://paste.osmc.tv/idohobejoq
very strange
strangewise
I had added the entry in another try:
dtoverlay=hifiberry-digi
which is deleted after I open via myOSMC.
Enable debug logging and upload logs after you try via MyOSMC
debug logging was enabled…
where can I confirm it?
try to verify it
https://paste.osmc.tv/abigahonoh
new log here.
But you didn’t upload logs. With that command you only uploaded the config.txt file.
Full log upload grab-logs -A
Are you sure you have chosen “Open Config.txt Editor”? Because your log file does not show any entries for config_editor.py
do you mean : in myOSMC edit config.txt?
yes I did this.
this is the screen when I press: PI Config in myOSMC
i do see:
14:34:41.607 T:1682436864 DEBUG: osmc_settings: <OSMCSettingClass(Thread-12, initial daemon)>
14:34:41.608 T:1682436864 DEBUG: osmc_settings: False
14:34:42.248 T:1203761920 DEBUG: OSMC PI Settings extracted from the config.txt
14:34:42.248 T:1203761920 DEBUG: OSMC PI hdmi_force_hotplug : false
latest log: https://paste.osmc.tv/momaxuxanu
Am I doing a wrong thing?
Well I don’t think that you are doing something wrong. But based on the picture above that doesn’t look right.
And I meant “Config Editor” → Open Config.txt Editor"
But based on the picture it might also be other addons breaking it
where do I find config.txt editor? in osmc?
I only used it via myOSMC : Pi config : that is the screen
or via nano …
