So my kids have lost my 4K remote and in the interim im trying to setup remote access via a smartphone app.
As far as I can tell I need to enable services on the player, but ive gone through everything I can but I still cannot connect; https://kodi.wiki/view/Smartphone/tablet_remotes#Manually_enabling_remote_control
Looking at my guisettings.xml I have the following;
<services>
<airplay default="true">true</airplay>
<airplaypassword default="true"></airplaypassword>
<airplayvideosupport default="true">true</airplayvideosupport>
<airplayvolumecontrol default="true">true</airplayvolumecontrol>
<devicename>osmc</devicename>
<esallinterfaces default="true">true</esallinterfaces>
<escontinuousdelay default="true">25</escontinuousdelay>
<esenabled default="true">true</esenabled>
<esinitialdelay default="true">750</esinitialdelay>
<esmaxclients default="true">20</esmaxclients>
<esport default="true">9777</esport>
<esportrange default="true">10</esportrange>
<upnpannounce default="true">true</upnpannounce>
<upnpcontroller default="true">false</upnpcontroller>
<upnplookforexternalsubtitles default="true">false</upnplookforexternalsubtitles>
<upnprenderer default="true">false</upnprenderer>
<upnpserver default="true">false</upnpserver>
<useairplaypassword default="true">false</useairplaypassword>
<webserver default="true">true</webserver>
<webserverpassword default="true"></webserverpassword>
<webserverport default="true">80</webserverport>
<webserverusername default="true"></webserverusername>
<webskin default="true">webinterface.default</webskin>
<zeroconf default="true">true</zeroconf>
</services>
I have also created an advancedsettings.xml file located in .kodi/userdata with the following;
<?xml version="1.0" encoding="UTF-8"?>
<advancedsettings>
<services>
<esallinterfaces>true</esallinterfaces>
<webserver>true</webserver>
<zeroconf>true</zeroconf>
</services>
</advancedsettings>
Have I missed anything obvious?
I have tried 3 apps from the app store, 2 are called Kodi Remote and another Sybu Kodi.
Both on same lan and can find the device successfully through auto discovery.
Yes I can access box through webbrowser via the ip address.
No reason for not setting username/password, this was the default setting.
Just set both these to osmc and no difference.
Have also just tried using “armchair” app, an app which is listed as a supported app on the link above and unable to connect.
I assume it is as IPhone and not an Android phone, or? If so I first would try with the official remote
https://kodi.wiki/view/Official_Kodi_Remote/iOS even so I doubt this makes a difference.
So if you can access and control Kodi from your Iphone Webbrowser and you can not access it from the remote using the same IP address, Port and login than I am not sure what is wrong.
Next step would be to enable debug logging and see if that gives any hints.
(notice the lost web connection in the bottom corner?)
I can browse via the web interface from my webbrowser (see above), but note the websocket error, I can only browse it, not control edit anything.
I can autodiscover the player via any number of apps but cannot connect.
Websocket port is set to 9090 in browser.
Adam1V:
Did you enable “Allow control from Application on other system”?
AFAIK port 9090 is only used for TCPv6
No to the first item, I don’t have UI access to the OS, can I change this via SSH?
Is it not;
Yeah seems that is the correct entry.
So I am at the end off my ideas. Maybe you have better luck at the Kodi Forum
This looks suspiciously like a Kodi bug.
On my Pi3, if I shut down Kodi and edit guisettings.xml to:
it resets itself to false when I restart.
osmc@osmc:~/.kodi/userdata$ sudo systemctl stop mediacenter
osmc@osmc:~/.kodi/userdata$ vi guisettings.xml
osmc@osmc:~/.kodi/userdata$ grep esallinterfaces guisettings.xml
osmc@osmc:~/.kodi/userdata$ sudo systemctl start mediacenter
<esallinterfaces default="true">false</esallinterfaces>
The workaround was to change the line to:
Edit: With some help from @fzinken , it looks like the two correct states of that option in guisettings.xml should be:
and
This is how mine looks like after I set it via GUI
