Update2…
So I think I’m getting somewhere…
first of all I stopped the following:
sudo systemctl stop eventlircd
sudo systemctl stop lircd_helper@lirc0
sudo systemctl stop system-lircd_helper.slice
sudo systemctl stop lircd_helper@event0
sudo systemctl stop lircd_helper@-dev-input-event0
I don’t know if some of these commands are redundant, I just applied all of them.
then when I ran ir-keytable this is the output:
Found /sys/class/rc/rc0/ (/dev/input/event0) with:
Name: TechnoTrend TT-connect S2-4600
Driver: dw2102, table: rc-tt-1500
LIRC device: /dev/lirc0
Supported kernel protocols: rc-5
Enabled kernel protocols: rc-5
bus: 3, vendor/product: 0b48:3011, version: 0x0000
Repeat delay = 500 ms, repeat period = 50 ms
and then when I ran sudo mode2 -d /dev/input/event0 this is the output:
Using driver devinput on device /dev/input/event0
Trying device: /dev/input/event0
Using device: /dev/input/event0
Running as regular user osmc
code: 0x4d30dc61123c0d001400010032000000
code: 0x4d30dc61123c0d000400040051050000
code: 0x4d30dc61123c0d000000000000000000
code: 0x4e30dc61f7d101000400040051050000
code: 0x4e30dc61f7d101000000000000000000
code: 0x4e30dc6194b80d0004000400510d0000
and after pressing ctl+c I started sudo irrecord -d /dev/input/event0 ~/temp.conf
I used temp.conf because at first I want to creat the conf file from scratch without the help of any template and at first irrecord asked me to keep pressing a key
Enter name of remote (only ascii, no spaces) :tt4600
Using tt4600.lircd.conf as output filename
Hold down an arbitrary key
Found gap (259967 us)
Please enter the name for the next button (press <ENTER> to finish recording)
and after that I started to record 5 keys just to try it, and this was the output:
begin remote
name tt4600
driver devinput
bits 16
eps 30
aeps 100
one 0 0
zero 0 0
pre_data_bits 112
pre_data 0x400040000
gap 259967
toggle_bit_mask 0x0
frequency 38000
begin codes
KEY_OK 0x0D4F
KEY_UP 0x054D
KEY_DOWN 0x0D51
KEY_LEFT 0x054E
KEY_RIGHT 0x0D50
end codes
end remote
I don’t really know if it is correct or not but any way copied it to /etc/lirc and selected it from my osmc->remotes and rebooted. It did not work.
As a seconed try I tried to record based on a conf file from the same manufacturer that I found in the LIRC remote database online and which I copied it to a file and named it tt3600.conf and ran sudo irrecord -d /dev/input/event0 ~/tt3600.conf and this was the output:
begin remote
name 3tt4600
driver devinput
bits 16
flags RC5|CONST_LENGTH
eps 30
aeps 100
one 838 838
zero 838 838
plead 940
pre_data_bits 112
gap 107304
min_repeat 1
# suppress_repeat 1
# uncomment to suppress unwanted repeats
toggle_bit_mask 0x800
frequency 38000
begin codes
KEY_OK 0x054F
KEY_UP 0x0D4D
KEY_DOWN 0x0551
KEY_LEFT 0x0D4E
KEY_RIGHT 0x0550
end codes
end remote
Same thing I did and copied it to /etc/lirc and selected it from my osmc->remotes and rebooted but it didn’t work either.
Here is my LOG after I kept the conf file generated from scratch and selected in my osmc->remotes LOG
Please If anyone could tell me what I’m doing wrong I would appreciate that
Regards
