Hello guys, I know I’m a couple of models behind but I’ve had my Raspberry Pi a couple of years now. I finally decided to make use of it and use it as a media centre. So I managed to get OSMC running, got a reliable wireless adapter. (TP-LINK TL-WN823N N300)
My problem is installing TVHeadend. I have tried to pick and unravel numerous ways to install and get TVHeadend working… to no avail. There seems to be numerous ways and I think I have got a little confused!
I was wondering if there is a way to start with TVHeadend again and if someone could point me in the right direction in terms of getting TVHeadend working?
I assume you are referring to TVHeadend Server, or?
Well the right and foul proof way is to go to the OSMC App Store and install it with one click.
If you have tried other ways before I suggest you start with a fresh install of OSMC
Well any entry that shows your TV Adapter and shows if e.g. Firmware is loaded.
You also can post your logs for review with grab-logs -A and post the URL
But what you quote above “TL-WN823N N300” is a wifi and not a TV adapter.
So you mean that you have one of these adapters?
It is used on the DVBSky T9580, TBS6281, TBS6285, Mystique SaTeCaBiX and PCTV 292e Triplestick (also contains EMPIA EM28174 controller)
So it seems that the firmware for your tuner is not found
Nov 06 19:00:50 OSMC kernel: si2168 3-0064: found a ‘Silicon Labs Si2168-B40’
Nov 06 19:00:50 OSMC kernel: si2168 3-0064: Direct firmware load for dvb-demod-si2168-b40-01.fw failed with error -2
Nov 06 19:00:50 OSMC kernel: si2168 3-0064: Direct firmware load for dvb-demod-si2168-02.fw failed with error -2
Nov 06 19:00:50 OSMC kernel: si2168 3-0064: firmware file ‘dvb-demod-si2168-02.fw’ not found
Nov 06 19:00:50 OSMC kernel: si2157 4-0060: found a ‘Silicon Labs Si2158-A20’
Nov 06 19:00:50 OSMC kernel: si2157 4-0060: Direct firmware load for dvb-tuner-si2158-a20-01.fw failed with error -2
Nov 06 19:00:50 OSMC kernel: si2157 4-0060: firmware file ‘dvb-tuner-si2158-a20-01.fw’ not found
So suggest to follow the instructions that are listed on this page in the firmware section https://www.linuxtv.org/wiki/index.php/Geniatech_T230
To copy the file into /lib/firmware you would need to use sudo cp dvb-*-si2158*.fw /lib/firmware/
