I did the installer and everything went great!
It seems to work great with a wired connection. I don’t have a Crystal HD card installed and have always used the onboard wifi. I tried looking around the GUI to see if there was a setting for it and could not find any. Is the internal wifi not supported? is there an additional add-on I could add to configure it. In the past with Crystalbuntu I used Netwok Manager in the programs to configure the wifi.
Please read the Wiki. Connecting to Wireless networks is well documented. The internal card may not be supported at this time however.
In the OSMC network config the only options shown are Wired and MySQL. I guess its not supported yet. Thanks.
I tried my raspberry wifi dongle.
Wifi finds my router but (once directly and once iafter a wike) after activating i get an
332.993722] GPIO IN=08
Rtw_ps_processor===> rfstate:rf_on
That’s a harmless message. Are you having any issues connecting to WiFi? If not, ignore this.
Harmless? I m just making a fresh install and ll try once more but the system stops functioning. Also restarts end with the same error…
Allow me to reiterate: the message you have posted is not indicative of an error.
Please upload a full log.
Happened again restart ends up with a very unhappy smiley i’ ll try to find a logfile but that might take a while… Have to find the tricks user name and password and so on in the forum…
Check out the Wiki, stuff like usernames and passwords, as well as how to get console access is all outlined there.
here is a part of the output of sudo journalctl;
nov 21 17:04:29 AtvOSMC1 kernel: ssb: Sonics Silicon Backplane found on PCI device 0000:02:00.0
nov 21 17:04:29 AtvOSMC1 kernel: rtl8192cu driver version=v4.0.2_9000.20130911
usb_endpoint_descriptor(0):
nov 21 17:04:29 AtvOSMC1 kernel: bLength=7
nov 21 17:04:29 AtvOSMC1 kernel: bDescriptorType=5
nov 21 17:04:29 AtvOSMC1 kernel: bEndpointAddress=81
nov 21 17:04:29 AtvOSMC1 kernel: wMaxPacketSize=200
nov 21 17:04:29 AtvOSMC1 kernel: bInterval=0
nov 21 17:04:29 AtvOSMC1 kernel: RT_usb_endpoint_is_bulk_in = 1
usb_endpoint_descriptor(1):
nov 21 17:04:29 AtvOSMC1 kernel: bEndpointAddress=2
nov 21 17:04:29 AtvOSMC1 kernel: RT_usb_endpoint_is_bulk_out = 2
usb_endpoint_descriptor(2):
nov 21 17:04:29 AtvOSMC1 kernel: bEndpointAddress=3
nov 21 17:04:29 AtvOSMC1 kernel: RT_usb_endpoint_is_bulk_out = 3
usb_endpoint_descriptor(3):
nov 21 17:04:29 AtvOSMC1 kernel: bEndpointAddress=84
nov 21 17:04:29 AtvOSMC1 kernel: wMaxPacketSize=40
nov 21 17:04:29 AtvOSMC1 kernel: bInterval=1
nov 21 17:04:29 AtvOSMC1 kernel: RT_usb_endpoint_is_int_in = 4, Interval = 1
nov 21 17:04:29 AtvOSMC1 kernel: nr_endpoint=4, in_num=2, out_num=2
nov 21 17:04:29 AtvOSMC1 kernel: USB_SPEED_HIGH
nov 21 17:04:29 AtvOSMC1 kernel: CHIP TYPE: RTL8188C_8192C
nov 21 17:04:29 AtvOSMC1 kernel: register rtw_netdev_ops to netdev_ops
nov 21 17:04:29 AtvOSMC1 kernel: Chip Version ID: VERSION_NORMAL_TSMC_CHIP_88C.
nov 21 17:04:29 AtvOSMC1 kernel: RF_Type is 3!!
nov 21 17:04:29 AtvOSMC1 kernel: EEPROM type is E-FUSE
nov 21 17:04:29 AtvOSMC1 kernel: ====> ReadAdapterInfo8192C
nov 21 17:04:29 AtvOSMC1 kernel: Boot from EFUSE, Autoload OK !
nov 21 17:04:29 AtvOSMC1 net.agent[1308]: ERROR: /sbin/ifup not found. You need to install the ifupdo
nov 21 17:04:29 AtvOSMC1 kernel: EEPROMVID = 0x7392
nov 21 17:04:29 AtvOSMC1 kernel: EEPROMPID = 0x7811
nov 21 17:04:29 AtvOSMC1 kernel: EEPROMCustomerID : 0x00
nov 21 17:04:29 AtvOSMC1 kernel: EEPROMSubCustomerID: 0x00
nov 21 17:04:29 AtvOSMC1 kernel: RT_CustomerID: 0x00
nov 21 17:04:29 AtvOSMC1 kernel: _ReadMACAddress MAC Address from EFUSE = 74:da:38:1a:d9:5e
nov 21 17:04:29 AtvOSMC1 kernel: EEPROMRegulatory = 0x0
nov 21 17:04:29 AtvOSMC1 kernel: _ReadBoardType(0)
nov 21 17:04:29 AtvOSMC1 kernel: BT Coexistance = disable
nov 21 17:04:29 AtvOSMC1 kernel: mlmepriv.ChannelPlan = 0x02
nov 21 17:04:29 AtvOSMC1 kernel: _ReadPSSetting...bHWPwrPindetect(1)-bHWPowerdown(0) ,bSupportRemoteW
nov 21 17:04:29 AtvOSMC1 kernel: ### PS params=> power_mgnt(0),usbss_enable(0) ###
nov 21 17:04:29 AtvOSMC1 kernel: ### AntDivCfg(0)
nov 21 17:04:29 AtvOSMC1 kernel: readAdapterInfo_8192CU(): REPLACEMENT = 1
nov 21 17:04:29 AtvOSMC1 kernel: <==== ReadAdapterInfo8192C in 450 ms
nov 21 17:04:29 AtvOSMC1 kernel: rtw_macaddr_cfg MAC Address = 74:da:38:1a:d9:5e
nov 21 17:04:29 AtvOSMC1 kernel: bDriverStopped:1, bSurpriseRemoved:0, bup:0, hw_init_completed:0
nov 21 17:04:29 AtvOSMC1 kernel: _rtw_drv_register_netdev, MAC Address (if1) = 74:da:38:1a:d9:5e
nov 21 17:04:29 AtvOSMC1 kernel: usbcore: registered new interface driver rtl8192cu
nov 21 17:04:30 AtvOSMC1 net.agent[1317]: net.agent add event for eth0 not handled.
nov 21 17:04:30 AtvOSMC1 kernel: nvidia: module license 'NVIDIA' taints kernel.
nov 21 17:04:30 AtvOSMC1 kernel: Disabling lock debugging due to kernel taint
nov 21 17:04:30 AtvOSMC1 kernel: vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,d
nov 21 17:04:30 AtvOSMC1 kernel: [drm] Initialized nvidia-drm 0.0.0 20151023 for 0000:01:00.0 on mino
nov 21 17:04:30 AtvOSMC1 kernel: NVRM: loading NVIDIA UNIX x86 Kernel Module 304.125 Mon Dec 1 19:
nov 21 17:04:30 AtvOSMC1 net.agent[1348]: ERROR: /sbin/ifup not found. You need to install the ifupdo
nov 21 17:04:30 AtvOSMC1 net.agent[1349]: net.agent add event for wlan0 not handled.
nov 21 17:04:30 AtvOSMC1 kernel: b43-phy0: Broadcom 4321 WLAN found (core revision 12)
nov 21 17:04:30 AtvOSMC1 kernel: b43-phy0: Found PHY: Analog 5, Type 4 (N), Revision 2
nov 21 17:04:30 AtvOSMC1 kernel: b43-phy0: Found Radio: Manuf 0x17F, ID 0x2055, Revision 4, Version 0
nov 21 17:04:30 AtvOSMC1 kernel: Broadcom 43xx driver loaded [ Features: PNL ]
nov 21 17:04:30 AtvOSMC1 kernel: b43 ssb0:0: Direct firmware load for b43/ucode11.fw failed with erro
nov 21 17:04:30 AtvOSMC1 kernel: b43 ssb0:0: Direct firmware load for b43-open/ucode11.fw failed with
nov 21 17:04:30 AtvOSMC1 kernel: b43-phy0 ERROR: Firmware file "b43/ucode11.fw" not found
nov 21 17:04:30 AtvOSMC1 kernel: b43-phy0 ERROR: Firmware file "b43-open/ucode11.fw" not found
nov 21 17:04:30 AtvOSMC1 kernel: b43-phy0 ERROR: You must go to http://wireless.kernel.org/en/users/D
nov 21 17:04:30 AtvOSMC1 kernel: hfsplus: Filesystem was not cleanly unmounted, running fsck.hfsplus
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: chmod(/var) failed: Read-only file system
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: chmod(/var/log) failed: Read-only file system
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: chmod(/tmp) failed: Read-only file system
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: rm_rf(/tmp): Read-only file system
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: remove(/tmp/.X0-lock): Read-only file system
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: chmod(/var/lib) failed: Read-only file system
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: chmod(/var/lib/systemd) failed: Read-only file syste
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: chmod(/var/lib/systemd/coredump) failed: Read-only f
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: Failed to create file /var/log/wtmp: Read-only file
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: Failed to create file /var/log/btmp: Read-only file
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: chmod(/var/cache) failed: Read-only file system
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: chmod(/var/lib/container) failed: Read-only file sys
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: chmod(/var/spool) failed: Read-only file system
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: chmod(/tmp/.X11-unix) failed: Read-only file system
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: chmod(/tmp/.ICE-unix) failed: Read-only file system
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: chmod(/tmp/.XIM-unix) failed: Read-only file system
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: chmod(/tmp/.font-unix) failed: Read-only file system
nov 21 17:04:30 AtvOSMC1 systemd-tmpfiles[1380]: chmod(/tmp/.Test-unix) failed: Read-only file system
nov 21 17:04:30 AtvOSMC1 systemd-update-utmp[1382]: Failed to write utmp record: Read-only file syste
nov 21 17:04:30 AtvOSMC1 systemd[1]: systemd-update-utmp.service: main process exited, code=exited, s
nov 21 17:04:30 AtvOSMC1 systemd[1]: Failed to start Update UTMP about System Boot/Shutdown.
nov 21 17:04:31 AtvOSMC1 systemd[1]: Dependency failed for Update UTMP about System Runlevel Changes.
nov 21 17:04:31 AtvOSMC1 systemd[1]: Unit systemd-update-utmp.service entered failed state.
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Found user 'avahi' (UID 105) and group 'avahi' (GID 108)
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Successfully dropped root privileges.
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: avahi-daemon 0.6.31 starting up.
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Successfully called chroot().
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Successfully dropped remaining capabilities.
nov 21 17:04:31 AtvOSMC1 dbus[1420]: [system] Successfully activated service 'org.freedesktop.systemd
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Loading service file /services/sftp.service.
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Loading service file /services/ssh.service.
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Loading service file /services/udisks.service.
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Network interface enumeration completed.
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Registering HINFO record with values 'I686'/'LINUX'.
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Server startup complete. Host name is AtvOSMC1.local. Lo
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Service "AtvOSMC1" (/services/udisks.service) successful
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Service "AtvOSMC1" (/services/ssh.service) successfully
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Service "AtvOSMC1" (/services/sftp.service) successfully
nov 21 17:04:31 AtvOSMC1 systemd-logind[1408]: New seat seat0.
nov 21 17:04:31 AtvOSMC1 systemd-logind[1408]: Watching system buttons on /dev/input/event1 (Power Bu
nov 21 17:04:31 AtvOSMC1 systemd-logind[1408]: Watching system buttons on /dev/input/event0 (Power Bu
nov 21 17:04:31 AtvOSMC1 connmand[1424]: Connection Manager version 1.30
nov 21 17:04:31 AtvOSMC1 connmand[1424]: Checking loopback interface settings
nov 21 17:04:31 AtvOSMC1 connmand[1424]: System hostname is AtvOSMC1
nov 21 17:04:31 AtvOSMC1 dbus[1420]: [system] Activating via systemd: service name='fi.w1.wpa_supplic
nov 21 17:04:31 AtvOSMC1 connmand[1424]: Failed to open RFKILL control device
nov 21 17:04:31 AtvOSMC1 connmand[1424]: lo {newlink} index 1 address 00:00:00:00:00:00 mtu 65536
nov 21 17:04:31 AtvOSMC1 connmand[1424]: lo {newlink} index 1 operstate 0 <UNKNOWN>
nov 21 17:04:31 AtvOSMC1 connmand[1424]: eth0 {create} index 2 type 1 <ETHER>
nov 21 17:04:31 AtvOSMC1 connmand[1424]: eth0 {update} flags 4098 <DOWN>
nov 21 17:04:31 AtvOSMC1 connmand[1424]: eth0 {newlink} index 2 address 00:23:32:34:7B:48 mtu 1500
nov 21 17:04:31 AtvOSMC1 connmand[1424]: eth0 {newlink} index 2 operstate 2 <DOWN>
nov 21 17:04:31 AtvOSMC1 connmand[1424]: Adding interface eth0 [ ethernet ]
nov 21 17:04:31 AtvOSMC1 connmand[1424]: wlan0 {create} index 3 type 1 <ETHER>
nov 21 17:04:31 AtvOSMC1 connmand[1424]: wlan0 {update} flags 4098 <DOWN>
nov 21 17:04:31 AtvOSMC1 connmand[1424]: wlan0 {newlink} index 3 address 74:DA:38:1A:D9:5E mtu 1500
nov 21 17:04:31 AtvOSMC1 connmand[1424]: wlan0 {newlink} index 3 operstate 2 <DOWN>
nov 21 17:04:31 AtvOSMC1 connmand[1424]: wlan0 runs an unsupported 802.11 driver
nov 21 17:04:31 AtvOSMC1 connmand[1424]: Adding interface wlan0 [ wifi ]
nov 21 17:04:31 AtvOSMC1 connmand[1424]: eth0 {update} flags 102467 <UP,RUNNING,LOWER_UP>
nov 21 17:04:31 AtvOSMC1 connmand[1424]: eth0 {newlink} index 2 operstate 0 <UNKNOWN>
nov 21 17:04:31 AtvOSMC1 dbus[1420]: [system] Activating via systemd: service name='org.freedesktop.h
nov 21 17:04:31 AtvOSMC1 connmand[1424]: open error Read-only file system for /var/lib/connman/ethern
nov 21 17:04:31 AtvOSMC1 connmand[1424]: Skipping disconnect of carrier, network is connecting.
nov 21 17:04:31 AtvOSMC1 connmand[1424]: ipconfig state 3 ipconfig method 1
nov 21 17:04:31 AtvOSMC1 connmand[1424]: eth0 {add} route ff00:: gw :: scope 0 <UNIVERSE>
nov 21 17:04:31 AtvOSMC1 connmand[1424]: eth0 {add} route fe80:: gw :: scope 0 <UNIVERSE>
nov 21 17:04:31 AtvOSMC1 connmand[1424]: eth0 {del} route fe80:: gw :: scope 0 <UNIVERSE>
nov 21 17:04:31 AtvOSMC1 connmand[1424]: eth0 {del} route ff00:: gw :: scope 0 <UNIVERSE>
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Joining mDNS multicast group on interface eth0.IPv4 with
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: New relevant interface eth0.IPv4 for mDNS.
nov 21 17:04:31 AtvOSMC1 avahi-daemon[1409]: Registering new address record for 192.168.0.38 on eth0.
nov 21 17:04:31 AtvOSMC1 connmand[1424]: Setting domainname to fritz.box
nov 21 17:04:31 AtvOSMC1 connmand[1424]: eth0 {add} address 192.168.0.38/24 label eth0 family 2
nov 21 17:04:31 AtvOSMC1 connmand[1424]: eth0 {add} route 192.168.0.0 gw 0.0.0.0 scope 253 <LINK>
nov 21 17:04:31 AtvOSMC1 connmand[1424]: eth0 {add} route 192.168.0.1 gw 0.0.0.0 scope 253 <LINK>
nov 21 17:04:31 AtvOSMC1 connmand[1424]: eth0 {add} route 0.0.0.0 gw 192.168.0.1 scope 0 <UNIVERSE>
nov 21 17:04:31 AtvOSMC1 kernel: 8139too 0000:03:03.0 eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
nov 21 17:04:32 AtvOSMC1 sshd[1442]: Server listening on 0.0.0.0 port 22.
nov 21 17:04:32 AtvOSMC1 sshd[1442]: Server listening on :: port 22.
nov 21 17:04:32 AtvOSMC1 sudo[1453]: osmc : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/rmdir /med
nov 21 17:04:32 AtvOSMC1 sudo[1453]: pam_unix(sudo:session): session opened for user root by (uid=0)
nov 21 17:04:32 AtvOSMC1 mediacenter[1454]: Failed to set capabilities on file `/usr/lib/kodi/kodi.bi
nov 21 17:04:32 AtvOSMC1 mediacenter[1454]: The value of the capability argument is not permitted for
nov 21 17:04:32 AtvOSMC1 sudo[1453]: pam_unix(sudo:session): session closed for user root
nov 21 17:04:32 AtvOSMC1 mediacenter[1454]: Starting Kodi...
nov 21 17:04:32 AtvOSMC1 sudo[1481]: root : TTY=unknown ; PWD=/ ; USER=osmc ; COMMAND=/usr/bin/xinit
nov 21 17:04:32 AtvOSMC1 bash[1452]: real 0m0.011s
nov 21 17:04:32 AtvOSMC1 bash[1452]: user 0m0.000s
nov 21 17:04:32 AtvOSMC1 bash[1452]: sys 0m0.000s
nov 21 17:04:32 AtvOSMC1 sudo[1481]: pam_unix(sudo:session): session opened for user osmc by (uid=0)
nov 21 17:04:32 AtvOSMC1 systemd-journal[747]: Runtime journal is using 4.0M (max allowed 11.9M, tryi
nov 21 17:04:32 AtvOSMC1 dbus[1420]: [system] Activating via systemd: service name='org.freedesktop.U
nov 21 17:04:32 AtvOSMC1 connmand[1424]: eth0 {add} route 178.62.84.106 gw 192.168.0.1 scope 0 <UNIVE
nov 21 17:04:32 AtvOSMC1 systemd[1]: systemd-hostnamed.service failed to run 'start' task: Read-only
nov 21 17:04:32 AtvOSMC1 dbus[1420]: [system] Successfully activated service 'org.freedesktop.UDisks'
nov 21 17:04:32 AtvOSMC1 connmand[1424]: eth0 {del} route 178.62.84.106 gw 192.168.0.1 scope 0 <UNIVE
nov 21 17:04:32 AtvOSMC1 systemd[1]: Failed to start Hostname Service.
nov 21 17:04:32 AtvOSMC1 systemd[1]: Unit systemd-hostnamed.service entered failed state.
nov 21 17:04:32 AtvOSMC1 dbus[1420]: [system] Activating via systemd: service name='org.freedesktop.P
nov 21 17:04:32 AtvOSMC1 dbus[1420]: [system] Successfully activated service 'fi.w1.wpa_supplicant1'
nov 21 17:04:32 AtvOSMC1 wpa_supplicant[1505]: Successfully initialized wpa_supplicant
nov 21 17:04:32 AtvOSMC1 rpcbind[1501]: Starting rpcbind daemon....
nov 21 17:04:33 AtvOSMC1 polkitd[1515]: started daemon version 0.105 using authority implementation `
nov 21 17:04:33 AtvOSMC1 dbus[1420]: [system] Successfully activated service 'org.freedesktop.PolicyK
nov 21 17:04:33 AtvOSMC1 udisks-glue[1489]: Device file /dev/sdb inserted
nov 21 17:04:37 AtvOSMC1 http-time[1463]: Updated time from Sat Nov 21 16:04:37 UTC 2015 to Sat Nov 2
nov 21 17:04:37 AtvOSMC1 ntpd[1544]: ntpd 4.2.6p5@1.2349-o Wed Oct 28 20:30:57 UTC 2015 (1)
nov 21 17:04:37 AtvOSMC1 ntp[1538]: Starting NTP server: ntpd.
nov 21 17:04:37 AtvOSMC1 ntpd[1545]: proto: precision = 2.235 usec
nov 21 17:04:37 AtvOSMC1 ntpd[1545]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
nov 21 17:04:37 AtvOSMC1 ntpd[1545]: Listen and drop on 1 v6wildcard :: UDP 123
nov 21 17:04:37 AtvOSMC1 ntpd[1545]: Listen normally on 2 lo 127.0.0.1 UDP 123
nov 21 17:04:37 AtvOSMC1 ntpd[1545]: Listen normally on 3 eth0 192.168.0.38 UDP 123
nov 21 17:04:37 AtvOSMC1 ntpd[1545]: Listen normally on 4 lo ::1 UDP 123
nov 21 17:04:37 AtvOSMC1 ntpd[1545]: peers refreshed
nov 21 17:04:37 AtvOSMC1 ntpd[1545]: Listening on routing socket on fd #21 for interface updates
nov 21 17:04:41 AtvOSMC1 sshd[1525]: Accepted password for osmc from 192.168.0.10 port 50461 ssh2
nov 21 17:04:41 AtvOSMC1 sshd[1525]: pam_unix(sshd:session): session opened for user osmc by (uid=0)
nov 21 17:04:41 AtvOSMC1 systemd-logind[1408]: New session c1 of user osmc.
nov 21 17:04:41 AtvOSMC1 systemd[1554]: pam_unix(systemd-user:session): session opened for user osmc
nov 21 17:04:41 AtvOSMC1 systemd[1554]: Starting Paths.
nov 21 17:04:41 AtvOSMC1 systemd[1554]: Reached target Paths.
nov 21 17:04:41 AtvOSMC1 systemd[1554]: Starting Timers.
nov 21 17:04:41 AtvOSMC1 systemd[1554]: Reached target Timers.
nov 21 17:04:41 AtvOSMC1 systemd[1554]: Starting Sockets.
nov 21 17:04:41 AtvOSMC1 systemd[1554]: Reached target Sockets.
nov 21 17:04:41 AtvOSMC1 systemd[1554]: Starting Basic System.
nov 21 17:04:41 AtvOSMC1 systemd[1554]: Reached target Basic System.
nov 21 17:04:41 AtvOSMC1 systemd[1554]: Starting Default.
nov 21 17:04:41 AtvOSMC1 systemd[1554]: Reached target Default.
nov 21 17:04:41 AtvOSMC1 systemd[1554]: Startup finished in 29ms.
nov 21 17:04:45 AtvOSMC1 systemd[1554]: Time has been changed
nov 21 17:04:45 AtvOSMC1 mediacenter[1454]: (EE)
nov 21 17:04:45 AtvOSMC1 mediacenter[1454]: Fatal server error:
nov 21 17:04:45 AtvOSMC1 mediacenter[1454]: (EE) Could not create lock file in /tmp/.tX0-lock
nov 21 17:04:45 AtvOSMC1 mediacenter[1454]: Please consult the The X.Org Foundation support
nov 21 17:04:45 AtvOSMC1 mediacenter[1454]: at http://wiki.x.org
nov 21 17:04:45 AtvOSMC1 mediacenter[1454]: for help.
nov 21 17:04:48 AtvOSMC1 mediacenter[1454]: xinit: giving up
nov 21 17:04:48 AtvOSMC1 mediacenter[1454]: xinit: unable to connect to X server: Connection refused
nov 21 17:04:48 AtvOSMC1 mediacenter[1454]: xinit: server error
nov 21 17:04:48 AtvOSMC1 sudo[1481]: pam_unix(sudo:session): session closed for user osmc
nov 21 17:04:48 AtvOSMC1 mediacenter[1454]: Kodi exited with return code 1 after 0 hours, 0 minutes a
nov 21 17:04:57 AtvOSMC1 dbus[1420]: [system] Failed to activate service 'org.freedesktop.hostname1':
nov 21 17:04:58 AtvOSMC1 mediacenter[1454]: Failed to set capabilities on file `/usr/lib/kodi/kodi.bi
nov 21 17:04:58 AtvOSMC1 mediacenter[1454]: The value of the capability argument is not permitted for
nov 21 17:04:58 AtvOSMC1 mediacenter[1454]: Starting Kodi...
nov 21 17:04:58 AtvOSMC1 sudo[1594]: root : TTY=unknown ; PWD=/ ; USER=osmc ; COMMAND=/usr/bin/xinit
nov 21 17:04:58 AtvOSMC1 sudo[1594]: pam_unix(sudo:session): session opened for user osmc by (uid=0)
nov 21 17:05:00 AtvOSMC1 sshd[1605]: Accepted password for osmc from 192.168.0.10 port 50462 ssh2
nov 21 17:05:00 AtvOSMC1 sshd[1605]: pam_unix(sshd:session): session opened for user osmc by (uid=0)
nov 21 17:05:00 AtvOSMC1 systemd-logind[1408]: New session c2 of user osmc.
nov 21 17:05:01 AtvOSMC1 sshd[1615]: Received disconnect from 192.168.0.10: 11: Closed due to user re
nov 21 17:05:01 AtvOSMC1 sshd[1605]: pam_unix(sshd:session): session closed for user osmc
nov 21 17:05:01 AtvOSMC1 systemd-logind[1408]: Removed session c2.
nov 21 17:05:02 AtvOSMC1 performance_tuner[1448]: swapon: /swap: swapon failed: Read-only file system
nov 21 17:05:02 AtvOSMC1 systemd[1]: performance.service: main process exited, code=exited, status=25
nov 21 17:05:04 AtvOSMC1 sshd[1645]: Accepted password for osmc from 192.168.0.10 port 50463 ssh2
nov 21 17:05:04 AtvOSMC1 sshd[1645]: pam_unix(sshd:session): session opened for user osmc by (uid=0)
nov 21 17:05:04 AtvOSMC1 systemd-logind[1408]: New session c3 of user osmc.
nov 21 17:05:10 AtvOSMC1 mediacenter[1454]: (EE)
nov 21 17:05:10 AtvOSMC1 mediacenter[1454]: Fatal server error:
nov 21 17:05:10 AtvOSMC1 mediacenter[1454]: (EE) Could not create lock file in /tmp/.tX0-lock
nov 21 17:05:10 AtvOSMC1 mediacenter[1454]: Please consult the The X.Org Foundation support
nov 21 17:05:10 AtvOSMC1 mediacenter[1454]: at http://wiki.x.org
nov 21 17:05:10 AtvOSMC1 mediacenter[1454]: for help.
nov 21 17:05:13 AtvOSMC1 mediacenter[1454]: xinit: giving up
nov 21 17:05:13 AtvOSMC1 sudo[1594]: pam_unix(sudo:session): session closed for user osmc
nov 21 17:05:13 AtvOSMC1 mediacenter[1454]: xinit: unable to connect to X server: Connection refused
nov 21 17:05:13 AtvOSMC1 mediacenter[1454]: xinit: server error
nov 21 17:05:13 AtvOSMC1 mediacenter[1454]: Kodi exited with return code 1 after 0 hours, 0 minutes a
nov 21 17:05:24 AtvOSMC1 mediacenter[1454]: Failed to set capabilities on file `/usr/lib/kodi/kodi.bi
nov 21 17:05:24 AtvOSMC1 mediacenter[1454]: The value of the capability argument is not permitted for
nov 21 17:05:24 AtvOSMC1 mediacenter[1454]: Starting Kodi...
nov 21 17:05:24 AtvOSMC1 sudo[1676]: root : TTY=unknown ; PWD=/ ; USER=osmc ; COMMAND=/usr/bin/xinit
nov 21 17:05:24 AtvOSMC1 sudo[1676]: pam_unix(sudo:session): session opened for user osmc by (uid=0)
nov 21 17:05:36 AtvOSMC1 mediacenter[1454]: (EE)
nov 21 17:05:36 AtvOSMC1 mediacenter[1454]: Fatal server error:
nov 21 17:05:36 AtvOSMC1 mediacenter[1454]: (EE) Could not create lock file in /tmp/.tX0-lock
nov 21 17:05:36 AtvOSMC1 mediacenter[1454]: Please consult the The X.Org Foundation support
nov 21 17:05:36 AtvOSMC1 mediacenter[1454]: at http://wiki.x.org
nov 21 17:05:36 AtvOSMC1 mediacenter[1454]: for help.
nov 21 17:05:39 AtvOSMC1 mediacenter[1454]: xinit: giving up
nov 21 17:05:39 AtvOSMC1 sudo[1676]: pam_unix(sudo:session): session closed for user osmc
nov 21 17:05:39 AtvOSMC1 mediacenter[1454]: xinit: unable to connect to X server: Connection refused
nov 21 17:05:39 AtvOSMC1 mediacenter[1454]: xinit: server error
nov 21 17:05:39 AtvOSMC1 mediacenter[1454]: Kodi exited with return code 1 after 0 hours, 0 minutes a
nov 21 17:05:50 AtvOSMC1 mediacenter[1454]: Failed to set capabilities on file `/usr/lib/kodi/kodi.bi
nov 21 17:05:50 AtvOSMC1 mediacenter[1454]: The value of the capability argument is not permitted for
nov 21 17:05:50 AtvOSMC1 mediacenter[1454]: Starting Kodi...
nov 21 17:05:50 AtvOSMC1 sudo[1702]: root : TTY=unknown ; PWD=/ ; USER=osmc ; COMMAND=/usr/bin/xinit
nov 21 17:05:50 AtvOSMC1 sudo[1702]: pam_unix(sudo:session): session opened for user osmc by (uid=0)
nov 21 17:06:02 AtvOSMC1 mediacenter[1454]: (EE)
nov 21 17:06:02 AtvOSMC1 mediacenter[1454]: Fatal server error:
nov 21 17:06:02 AtvOSMC1 mediacenter[1454]: (EE) Could not create lock file in /tmp/.tX0-lock
nov 21 17:06:02 AtvOSMC1 mediacenter[1454]: Please consult the The X.Org Foundation support
nov 21 17:06:02 AtvOSMC1 mediacenter[1454]: at http://wiki.x.org
nov 21 17:06:02 AtvOSMC1 mediacenter[1454]: for help.
nov 21 17:06:05 AtvOSMC1 mediacenter[1454]: xinit: giving up
nov 21 17:06:05 AtvOSMC1 sudo[1702]: pam_unix(sudo:session): session closed for user osmc
nov 21 17:06:05 AtvOSMC1 mediacenter[1454]: xinit: unable to connect to X server: Connection refused
nov 21 17:06:05 AtvOSMC1 mediacenter[1454]: xinit: server error
nov 21 17:06:05 AtvOSMC1 mediacenter[1454]: Kodi exited with return code 1 after 0 hours, 0 minutes a
nov 21 17:06:15 AtvOSMC1 mediacenter[1454]: Failed to set capabilities on file `/usr/lib/kodi/kodi.bi
is there any way to use the internal wifi card? i dont own a wifi dongle and even if i do how could i use it when the usb port is used by the osmc usb loader stick?
on crystalbuntu it was possible to select it in network options
I found the problem with my wifi dongle. at first I thought the dongle did not have the correct write permissions. . So i tried chmod -w…and so on… Didn’t work. Today i bought a new usb card and… Works like a charm. So my€10 wifi dongle (Edimax WiFi-stick N150 Nano EW-7811UN) works fine. Now i’m gonna try the harddisk install and can try something new with my now free raspberry pi…
I have the same problem, all I see is “Wired” and “SQL”. What do you mean by “internal card”? Can’t it work with a wireless router like an Airport Express?
this addon/repo worked perfect for the internal wifi card to connect to time capsule / airport express on crystalubuntu for apple tv.
http://forum.kodi.tv/showthread.php?tid=130816
i don’t know if it works on osmc, probably it needs a update.
here you find a helix version of it: http://www.xilka.com/xilka/source/script.linux.nm1-1.0.3.zip
i am in the same situation like you, the author didnt say in it’s wiki that it is not working with the internal card. now i have a useless apple tv with omsc but no wifi and usb port is in use for the loader so i can’t even watch a movie from usb port. as the apple tv got only 1 usb port which uses the osmc loader i see no option to connect a extern wifi dongle.
i hope so much for a working internal wifi card addon in next release as in the link above
Most people have replaced the internal Wifi with the Crystal HD card, since the CHD is what makes the ATV1 capable of playing back higher resolution video.
Because of this, the internal wifi is currently not supported. If demand warrants it, it can be added.
Please make your want known in the Feature Requests area:
Feature Requests - OSMC Forums
This is normal, the Wireless Menu only appears when your card is supported by OSMC.
Please give full details of the make/model of the card/dongle you want support for when you post the request. Keep In mind that some hardware does not have linux drivers available at all.
The old network addon manager did not add support for the internal Wifi. It simply added an easy to use gui for configuring it within XBMC.
Wifi Adapter support has to added at the OS level.
You can easily plug a USB hub into the ATV. You can then connect both the USB stick with OSMC on it, and A WIfi Dongle to the hub.
I’ve got the USB stick and a Bluetooth dongle currently hooked up to a hub and it works fine.
The ultimate option, in my personal opinion, is to use a Wireless Bridge instead of a dongle.
ATV->Ethernet cable–>Wireless bridge–> Wifi network.
But this is overkill for many people.
As Sam said earlier in the thread, network configuration is covered in the wiki. Wiki - OSMC
If the wireless option doesn’t show up in the network menu, it’s because your Wifi Adapter is not currently supported.
I don’t own a ATV, but just wondering couldn’t you just use a USB Hub to connect more then one USB device?
ok right a hub wold probably work
anyways, i managed to install network manager 1.0.3 whch was for crystalubuntu which appears now in the programs section of kodi but it does not start. it seems to need a update.
so at the moment i feel just bad that i did uninstall crystalubuntu. wiki did not say that i have to buy a usb hub + extra dongle for wifi for a old atv
You don’t. You can use the internal adapter, but you might need to add the firmware for it. The driver should already be included in the kernel. Without any dmesg output, I can’t know for sure however.
sam: how can i do that dmesgoutput for you?
To upload the dmesg you would need to temporary get a network connection (wired).
Then you could use the Log Uploader under MyOSMC to upload the dmesg (ensure you have the respective entry ticked). When done you get an URL which you could share here.
