Under System, MY OSMC is no longer available. Can you help? This negates my manual update and other tweaks to the system.
I’m running the Confluence skin via download I think the jeezy version. What addon am I looking for?
MyOSMC addon, obviously. If it’s enabled, check Programs menu.
We used to patch Confluence to add these options
As of Kodi v17, Confluence is no longer the default skin. It’s now distributed via Kodi’s repository. We are no longer in a position to patch it.
My OSMC can now be found under the Programs menu.
I’ve started to use Xonfluence. It’s like a unlocked version of Confluence. If you google it instructions can be found on how to DL & videos on configuration. I found it very easy to configure and use.
