I installed OSMC on a new card as suggested on your help page (I did not format card initially - thought installer will do it) . Everything works on Pi. But when I pull SD card from Pi and hook on my computer first it shows that SD card is formatted on FAT32 (with total size of 239MB instead of 32GB) and with unfamiliar directory and file structure.
Is there a partition I cannot see?
My directory listing:
\dtb-4.9.29-13-osmc
\overlays
\bcm2708-rpi-0-w.dtb
\bcm2708-rpi-b.dtb
\bcm2708-rpi-b-plus.dtb
\bcm2708-rpi-cm.dtb
\bcm2709-rpi-2-b.dtb
\bcm2710-rpi-3-b.dtb
\bcm2710-rpi-cm3.dtb
\bcm2835-rpi-a.dtb
\bcm2835-rpi-a-plus.dtb
\bcm2835-rpi-b.dtb
\bcm2835-rpi-b-plus.dtb
\bcm2835-rpi-b-rev2.dtb
\bcm2835-rpi-zero.dtb
\bcm2836-rpi-2-b.dtb
\bootcode.bin
\cmdline.txt
\config.txt
\config-4.9.29-13-osmc
\fixup_x.dat
\install.log
\kernel.img
\LICENCE.broadcom
\preseed.cfg
\start_x.elf
\System.map-4.9.29-13-osmc
\vmlinuz-4.9.29-13-osmc
