Hello,
I’ve had a look through the forums and I don’t think I’ve found anything that explicitly answers this. I use both the wired and wireless connections simultaneously. The wired connection is to a Windows box which acts as a file server. The wireless connection is mostly used for remote control access using phone apps and the occasional remote login. Right now, when I start up OSMC, the wireless connection isn’t enabled by default because of the wired connection. How can I easily set it so that both connections are activated on startup?
Thanks!
