osmc@osmc:~$ dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.5-2-osmc (root@cubox-i) (gcc version 4.9.1 (Raspbian 4.9.1-19) ) #1 PREEMPT Sun Feb 1 18:32:16 UTC 2015
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi Model B+
[ 0.000000] cma: Reserved 8 MiB at 0x16800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] On node 0 totalpages: 94208
[ 0.000000] free_area_init_node: node 0, pgdat c098edec, node_mem_map d6514000
[ 0.000000] Normal zone: 736 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 94208 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 93472
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708.boardrev=0x10 bcm2708.serial=0x94c9cc1f smsc95xx.macaddr=B8:27:EB:C9:CC:1F bcm2708_fb.fbswap=1 bcm2708.disk_led_gpio=47 bcm2708.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 354652K/376832K available (7277K kernel code, 356K rwdata, 1828K rodata, 324K init, 726K bss, 22180K reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
vmalloc : 0xd7800000 - 0xff000000 ( 632 MB)
lowmem : 0xc0000000 - 0xd7000000 ( 368 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc08ec6c0 (9106 kB)
.init : 0xc08ed000 - 0xc093e000 ( 324 kB)
.data : 0xc093e000 - 0xc09973ec ( 357 kB)
.bss : 0xc09973ec - 0xc0a4cc68 ( 727 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:522
[ 0.000024] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483648000ns
[ 0.000071] Switching to timer-based delay loop, resolution 1000ns
[ 0.000343] Console: colour dummy device 80x30
[ 0.000555] console [tty0] enabled
[ 0.000580] Calibrating delay loop (skipped), value calculated using timer frequency… 2.00 BogoMIPS (lpj=10000)
[ 0.000606] pid_max: default: 32768 minimum: 301
[ 0.000951] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000979] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001917] Initializing cgroup subsys memory
[ 0.001970] Initializing cgroup subsys devices
[ 0.001999] Initializing cgroup subsys freezer
[ 0.002026] Initializing cgroup subsys net_cls
[ 0.002049] Initializing cgroup subsys blkio
[ 0.002138] CPU: Testing write buffer coherency: ok
[ 0.002212] ftrace: allocating 17798 entries in 53 pages
[ 0.092724] Setting up static identity map for 0x6b7c48 - 0x6b7ca4
[ 0.095432] devtmpfs: initialized
[ 0.112122] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.115308] pinctrl core: initialized pinctrl subsystem
[ 0.117737] NET: Registered protocol family 16
[ 0.122934] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.152484] cpuidle: using governor ladder
[ 0.182536] cpuidle: using governor menu
[ 0.182770] bcm2708.uart_clock = 3000000
[ 0.185717] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.185743] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.185779] mailbox: Broadcom VideoCore Mailbox driver
[ 0.185909] bcm2708_vcio: mailbox at f200b880
[ 0.186015] bcm_power: Broadcom power driver
[ 0.186036] bcm_power_open() → 0
[ 0.186048] bcm_power_request(0, 8)
[ 0.686771] bcm_mailbox_read → 00000080, 0
[ 0.686792] bcm_power_request → 0
[ 0.686946] Serial: AMBA PL011 UART driver
[ 0.687144] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.745818] SCSI subsystem initialized
[ 0.746136] usbcore: registered new interface driver usbfs
[ 0.746260] usbcore: registered new interface driver hub
[ 0.746428] usbcore: registered new device driver usb
[ 0.748207] Switched to clocksource stc
[ 0.774378] FS-Cache: Loaded
[ 0.774780] CacheFiles: Loaded
[ 0.790323] NET: Registered protocol family 2
[ 0.791667] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.791771] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.791873] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.791958] TCP: reno registered
[ 0.791985] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.792029] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.792372] NET: Registered protocol family 1
[ 0.793014] RPC: Registered named UNIX socket transport module.
[ 0.793044] RPC: Registered udp transport module.
[ 0.793057] RPC: Registered tcp transport module.
[ 0.793068] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.793667] bcm2708_dma: DMA manager at f2007000
[ 0.793845] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 0.795339] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.795475] audit: initializing netlink subsys (disabled)
[ 0.795572] audit: type=2000 audit(0.730:1): initialized
[ 0.810676] VFS: Disk quotas dquot_6.5.2
[ 0.811051] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.813720] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.815422] NFS: Registering the id_resolver key type
[ 0.815517] Key type id_resolver registered
[ 0.815535] Key type id_legacy registered
[ 0.816872] msgmni has been set to 708
[ 0.820229] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.820642] io scheduler noop registered
[ 0.821257] io scheduler bfq registered (default)
[ 0.821278] BFQ I/O-scheduler version: v7r7
[ 0.823572] BCM2708FB: allocated DMA memory 56c00000
[ 0.823640] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 0.830466] Console: switching to colour frame buffer device 90x30
[ 0.835541] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 0.835955] uart-pl011 dev:f1: no DMA platform data
[ 0.836655] vc-cma: Videocore CMA driver
[ 0.836680] vc-cma: vc_cma_base = 0x00000000
[ 0.836694] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.836706] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.849750] brd: module loaded
[ 0.856447] loop: module loaded
[ 0.856867] vchiq: vchiq_init_state: slot_zero = 0xd6800000, is_master = 0
[ 0.858042] Loading iSCSI transport class v2.0-870.
[ 0.859547] usbcore: registered new interface driver smsc95xx
[ 0.859677] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.060067] Core Release: 2.80a
[ 1.060104] Setting default values for core params
[ 1.060133] Finished setting default values for core params
[ 1.260296] Using Buffer DMA mode
[ 1.260324] Periodic Transfer Interrupt Enhancement - disabled
[ 1.260337] Multiprocessor Interrupt Enhancement - disabled
[ 1.260350] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.260367] Dedicated Tx FIFOs mode
[ 1.260805] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xd6c14000 dma = 0x56c14000 len=9024
[ 1.260843] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 1.260872] dwc_otg: Microframe scheduler enabled
[ 1.260939] WARN::hcd_init:473: FIQ at 0xc04fb608
[ 1.260960] WARN::hcd_init:474: FIQ ASM at 0xc04fb8e4 length 36
[ 1.260992] WARN::hcd_init:500: MPHI regs_base at 0xd7806000
[ 1.261028] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.261084] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.261151] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.261191] Init: Port Power? op_state=1
[ 1.261203] Init: Power Port (0)
[ 1.261587] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.261614] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.261631] usb usb1: Product: DWC OTG Controller
[ 1.261648] usb usb1: Manufacturer: Linux 3.18.5-2-osmc dwc_otg_hcd
[ 1.261663] usb usb1: SerialNumber: bcm2708_usb
[ 1.262775] hub 1-0:1.0: USB hub found
[ 1.262887] hub 1-0:1.0: 1 port detected
[ 1.263508] dwc_otg: FIQ enabled
[ 1.263528] dwc_otg: NAK holdoff enabled
[ 1.263540] dwc_otg: FIQ split-transaction FSM enabled
[ 1.263598] Module dwc_common_port init
[ 1.264118] usbcore: registered new interface driver usb-storage
[ 1.264539] mousedev: PS/2 mouse device common for all mice
[ 1.265818] bcm2835-cpufreq: min=700000 max=850000
[ 1.266167] sdhci: Secure Digital Host Controller Interface driver
[ 1.266186] sdhci: Copyright(c) Pierre Ossman
[ 1.266452] DMA channels allocated for the MMC driver
[ 1.298266] Load BCM2835 MMC driver
[ 1.298624] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.299157] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.299338] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.299672] usbcore: registered new interface driver usbhid
[ 1.299689] usbhid: USB HID core driver
[ 1.300067] TCP: cubic registered
[ 1.300095] Initializing XFRM netlink socket
[ 1.300143] NET: Registered protocol family 17
[ 1.300365] Key type dns_resolver registered
[ 1.301729] registered taskstats version 1
[ 1.302029] vc-sm: Videocore shared memory driver
[ 1.302056] [vc_sm_connected_init]: start
[ 1.310794] [vc_sm_connected_init]: end - returning 0
[ 1.318621] Waiting for root device /dev/mmcblk0p2…
[ 1.346522] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.348879] mmc0: new high speed SDHC card at address 0007
[ 1.349669] mmcblk0: mmc0:0007 SD8GB 7.42 GiB
[ 1.351318] mmcblk0: p1 p2
[ 1.434209] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.434247] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.458510] Indeed it is in host mode hprt0 = 00021501
[ 1.638413] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.638625] Indeed it is in host mode hprt0 = 00001101
[ 1.838735] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.838770] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.840009] hub 1-1:1.0: USB hub found
[ 1.840196] hub 1-1:1.0: 5 ports detected
[ 2.118382] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.218749] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.218782] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.221931] smsc95xx v1.0.4
[ 2.282643] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:c9:cc:1f
[ 2.358382] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 2.460196] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8176
[ 2.460227] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.460249] usb 1-1.4: Product: 802.11n WLAN Adapter
[ 2.460266] usb 1-1.4: Manufacturer: Realtek
[ 2.460281] usb 1-1.4: SerialNumber: 00e04c000001
[ 3.955502] EXT4-fs (mmcblk0p2): recovery complete
[ 3.988201] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.988376] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.998533] devtmpfs: mounted
[ 3.999612] Freeing unused kernel memory: 324K (c08ed000 - c093e000)
[ 5.599744] random: systemd urandom read with 85 bits of entropy available
[ 5.681580] NET: Registered protocol family 10
[ 6.337227] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 6.584987] fuse init (API version 7.23)
[ 6.818778] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.658700] systemd-udevd[96]: starting version 215
[ 8.915693] cfg80211: Calling CRDA to update world regulatory domain
[ 9.368352] random: nonblocking pool is initialized
[ 9.493361] rtl8192cu: Chip version 0x10
[ 9.624280] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 10.092661] systemd-journald[76]: Received request to flush runtime journal from PID 1
[ 10.721606] rtl8192cu: MAC address: 00:13:ef:70:05:24
[ 10.721664] rtl8192cu: Board Type 0
[ 10.721924] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 10.722100] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin
[ 10.775550] ieee80211 phy0: Selected rate control algorithm ‘rtl_rc’
[ 10.785043] usbcore: registered new interface driver rtl8192cu
[ 11.421958] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 14.323928] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 14.326696] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.570119] rtl8192cu: MAC auto ON okay!
[ 14.712079] rtl8192cu: Tx queue select: 0x05
[ 15.768675] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 22.048928] Console: switching to colour dummy device 80x30
[ 57.230436] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 57.241106] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 1256.912296] wlan0: authenticate with 6c:b0:ce:17:ae:a6
[ 1256.941475] wlan0: send auth to 6c:b0:ce:17:ae:a6 (try 1/3)
[ 1257.048358] wlan0: send auth to 6c:b0:ce:17:ae:a6 (try 2/3)
[ 1257.074870] wlan0: authenticated
[ 1257.078462] wlan0: associate with 6c:b0:ce:17:ae:a6 (try 1/3)
[ 1257.188292] wlan0: associate with 6c:b0:ce:17:ae:a6 (try 2/3)
[ 1257.222263] wlan0: RX AssocResp from 6c:b0:ce:17:ae:a6 (capab=0x431 status=0 aid=5)
[ 1257.222874] rtl8192cu:rtl92cu_set_hw_reg():<0-0> switch case not processed
[ 1257.223142] rtl8192c_common:rtl92c_fill_h2c_cmd(): return H2C cmd because of Fw download fail!!!
[ 1257.225612] rtl8192c_common:rtl92c_fill_h2c_cmd(): return H2C cmd because of Fw download fail!!!
[ 1257.225802] rtl8192c_common:rtl92c_fill_h2c_cmd(): return H2C cmd because of Fw download fail!!!
[ 1257.226544] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 1257.235695] wlan0: associated
[ 1257.240113] cfg80211: Calling CRDA to update world regulatory domain
[ 1260.309915] wlan0: deauthenticating from 6c:b0:ce:17:ae:a6 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 1260.314157] rtl8192c_common:rtl92c_fill_h2c_cmd(): return H2C cmd because of Fw download fail!!!
[ 1260.365405] cfg80211: Calling CRDA for country: US
[ 1260.404312] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 1368.920482] smsc95xx 1-1.1:1.0 eth0: link down
[ 1369.030758] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 1369.087961] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 1370.167830] wlan0: authenticate with 6c:b0:ce:17:ae:a6
[ 1370.199613] wlan0: send auth to 6c:b0:ce:17:ae:a6 (try 1/3)
[ 1370.273393] wlan0: authenticated
[ 1370.288407] wlan0: associate with 6c:b0:ce:17:ae:a6 (try 1/3)
[ 1370.293233] wlan0: RX AssocResp from 6c:b0:ce:17:ae:a6 (capab=0x431 status=0 aid=5)
[ 1370.293664] rtl8192cu:rtl92cu_set_hw_reg():<0-0> switch case not processed
[ 1370.293981] rtl8192c_common:rtl92c_fill_h2c_cmd(): return H2C cmd because of Fw download fail!!!
[ 1370.296472] rtl8192c_common:rtl92c_fill_h2c_cmd(): return H2C cmd because of Fw download fail!!!
[ 1370.296757] rtl8192c_common:rtl92c_fill_h2c_cmd(): return H2C cmd because of Fw download fail!!!
[ 1370.297456] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 1370.300748] wlan0: associated
[ 8040.907100] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8040.919261] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 8044.078442] wlan0: deauthenticating from 6c:b0:ce:17:ae:a6 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 8044.081384] rtl8192c_common:rtl92c_fill_h2c_cmd(): return H2C cmd because of Fw download fail!!!
[ 8044.110133] cfg80211: Calling CRDA to update world regulatory domain
[ 8044.248375] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
