When i run a my 2 vero’s without a vpn I get 190mbs. When I connect using vpn manager for open vpn it drops either to about 34 mbs or 0 mbs with a ping of 1800000. I don’t think its the vpn as other devices hardly drop at all maybe from 200 to 180 mbs.
Is there a better way o connect to the vpn. did try brian hornsby app but didn’t understand how to set it up.
You mean Internet speed through the VPN?
Without Hardware Encryption this would be expected.
Check this thread
just checked with iperf3 and got
[ ID] Interval Transfer Bitrate Retr
[ 5] 0.00-10.01 sec 39.9 MBytes 33.4 Mbits/sec 23 sender
[ 5] 0.00-10.00 sec 39.0 MBytes 32.7 Mbits/sec receiver
which seems a bit slow. my connection is ethernet into a mesh node with a dedicated 5ghz wifi backhaul.
This is on your LAN or via VPN?
Sorry for delay, work got in the way.
this is on vero’s with vpn enabled, just tried with both vero’s vpn’s disabled and its the same.
Just remember realised what you’re asking. The vpn is on the individual Vero’s
