I wanted to close down the MySQL user for the kodi DB and kinda f’ed up it seams.
I created a new user and it seemed to work, so I removed the old user.
From then on it didn’t work anymore.
I have setup the following user:
I have the following permissions set:
When I try to connect from my Vero 4K it works from the commandline:
But I keep getting errors within the kodi log:>
2021-03-21 21:50:05.308 T:3947561184 NOTICE: MYSQL: Connected to version 10.3.21-MariaDB
2021-03-21 21:50:05.359 T:3947561184 NOTICE: Running database version MyMusic72
2021-03-21 21:50:05.376 T:3947561184 NOTICE: Running database version MyVideos116
2021-03-21 21:50:05.379 T:3947561184 NOTICE: Running database version TV32
2021-03-21 21:50:05.381 T:3947561184 NOTICE: Running database version Epg12
2021-03-21 21:50:05.382 T:4066721808 NOTICE: start dvd mediatype detection
2021-03-21 21:50:05.453 T:4066721808 NOTICE: load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.27)
2021-03-21 21:50:05.778 T:4066721808 ERROR: Window Translator: Can’t find window InfoDialog
2021-03-21 21:50:05.923 T:4066721808 ERROR: SQL: [MyMusic72] Undefined MySQL error: Code (1045)
Query: select count(idSong) as NumSongs from songview
2021-03-21 21:50:05.923 T:4066721808 ERROR: GetSongsCount() failed
2021-03-21 21:50:06.135 T:3947561184 ERROR: SQL: [MyVideos116] Undefined MySQL error: Code (1045)
Query: SELECT movie_view.idSet,COUNT(1) AS c FROM movie_view JOIN sets ON sets.idSet = movie_view.idSet GROUP BY
movie_view.idSet HAVING c>1
2021-03-21 21:50:06.135 T:3947561184 ERROR: HasSets failed
Not sure, but please be aware you can NOT limit the permission for the user as for every Kodi upgrade it will create a new Database so the Kodi user require full rights. The only way to secure the Database is to have a dedicated database running for Kodi (e.g. either on one of the Kodi machines or in a Docker).
Actually one reminder, after changing any user permissions you need to reload the permissions with FLUSH PRIVILEGES;
Than it should be same same. You can enable component specific logging for MySQL in Kodi to figure out whats going on. Or check binlog on the MySQL server.
I think your issue was the Grant permissions, as per the official setup…
Type in: CREATE USER 'kodi' IDENTIFIED BY 'kodi'; and press return
Type in: GRANT ALL ON *.* TO 'kodi'; and press return
Type in: flush privileges; and press return
Not really, the xbmc user and kodi user have the same privileges.
The databases have been created with the xbmc user, maybe it’s that.
What you just named is the basic user creation and setting of global privileges, but if you share your mysql server with other databases, you better set the database specific privileges from a security point of view.
I see. To be fair I used to get a lot of mariadb database corruption in my setup. Database would become inaccessible and I would restore from daily backups, but I never really investigated. Have since abandoned that setup for an emby backend.
I still have the database, since I use MariaDB for other things. Should attach it to a spare kodi box and check if it is the same issue you are having.
I will do that tonight.
