Hello,
I’m running osmc on a RPI3. I have plugged in an additional wifi card hoping that I can make the PI connect to two different access points so that I can setup some routing rules to make certain traffic go through a specific gateway. But I’m stuck at setting connmanctl to connect to two different Access points. Any suggestions?
connmanctl should show all services available when you run scan wifi
you should be able to run connect …
However: on reboot, reconnection won’t be automatic to both adapters, so you may want to add a reconnection command in rc.local
