Hi I am plagued with distortion of my picture and few drops of audio.
Looks like the guys at libreelec are having the same problem since the switch to kernel 4.9
https://forum.libreelec.tv/thread/4235-dvb-issue-since-le-switched-to-kernel-4-9-x/
I was wondering if i was the only one? I would also like to downgrade to 4.8 to see if it is the same error.
I think that this is an upstream issue.
Thanks for a link to the thread. I’ll keep an eye on it. Once there’s a fix
we will include it.
Wego
26 August 2017 19:22
#3
You’re, not the only one. I had to downgrade to the April release to get rid of these annoying continuity errors.
What if i re-install to the latest known kernel (April release) and mark the kernel on hold would i still get my kernel upgraded after that if i do my updates via the osmc addon?
You can try it but you’ll be running a unsupported version of OSMC
the_bo
10 November 2017 18:55
#6
A bug has been reported on this issue. Hopefully will get patched in soon.
https://bugzilla.kernel.org/show_bug.cgi?id=197835
smp1
5 January 2018 02:53
#7
The cause of the issue was found .
@sam_nazarko can you include this patch in OSMC?
