Control via tablet
I use an IR remote to control my vero 4k+. I can also control my Denon amp via an app on my Android tablet, is there a similar option for the vero ? Thanks
Check the Yatse App under Android
or Kore
Thanks both I shall have a play and report back in a few days.
Kore worked fine thanks folks
Good to hear, while I still recommend to take a look at Yatse
