Sorry to create a new post on that one, but after spending hours to read many other threads, I’m struggling to find a “real solution”.
My problem is the following:
When I transfer a file via SFTP (Filezilla) from my computer to an HDD external connected to the Vero4K device, the speed transfer is super slow… not exceeding 4.8MB/s)
My configuration:
Laptop connected on 5Ghz wireless
Vero4k connected to the same network (I tried both: wireless & wired, same result)
4.8 megabytes per second is 38.4 megabits per second, which is not very far away from your measured network speed from laptop to Vero; so it seems like the network speed might be the limiting factor.
Yes it was my first reaction as well, but this limitation seems to be due to the Vero4k network performance itself rigth ?
As I got the same perf in wireless or wired ?
Also my laptop is capable to go up to 50Mo/s in wireless, so the problem is defenetly not my local router.
I was also considering to unplugged/unplugged the USB drive everytime, but not really convenient with all those powercable behind the TV furniture
As fzinken says, it would be a little surprising if the Vero’s network speed was limited to 40Mb/s on wired Ethernet. (If is, there’s certainly something odd going on). As well as checking iPerf numbers with the Vero connected by wire, you might also want to get some numbers for when both the Vero and the laptop have a wired connection - it could be that the laptop’s upstream speed over WiFi is slow.
Also, is this a Vero 4K, or a Vero 4K+?
And, when using wired connections, are both devices connected directly to the router, or are there other devices involved (e.g. an Ethernet switch or a power line adapter)?
Just did a quick speedtest on Internet just to show you (not fully reflecting reality as I have a fiber 2Gb link, but still)
In fact the upload is even better than the download, so I should be able to upload even faster to the Vero
I did a file transfer test between the router and my laptop: 1Go file in 30s
Yes the wireless module was disabled when I was connected on wired.
I just did a new test (wireless only this time)
We can already see a big difference between income/outcome … which looks already super weird for me. I should get same performances in both ways
Can you connect the Vero wired again, do a iperf3 test and upload logs via MyOSMC. Something is surely odd here.
Can you also for testing connect the notebook wired?
Also do you have any other device you can test from with iperf3?
