when I do clean installation of 2021.08-1 Vero 4K is not able to connect to any repositories event the basic one.
reproduce the issue
upload the log set (all configs and logs!) either using the
Post logs, please.
- download the image
- balenaEtcher → creating USB disk
- installation (Vero 4k)
- wizard → Czech, Prague, …
- Addons → Install from repozitory → Could not connect to repository →
(kernel panic?)
This should now be solved.
The installer was also affected, it couldn’t download the image 5 minutes ago. But it seems like this is also solved now, because it is working again.
Yes – everything should work as expected now.
