do you have any idea how to avoid the Could not save the timer Error? Its appearance is random - there is no clear link to any other setting. Sometimes the record timer works without any problem, later with the error. Any idea what to check?
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
This is not related to your issue, which I can’t help with, but you should set your UI resolution to 1080p (progressive). It is currently set on interlaced and that is suboptimal. I would also recommend changing your “adjust display refresh rate” to “on start/stop” instead of the setting you are currently using.
