I recently got my Vero V. Couple of random questions:
It’s crashed to the blue frowny face a couple of times now, seemingly at random. While that is annoying in itself every time it happens the main menu resets to default. When I go to fix it the ‘skin shortcuts’ addon gets (re)installed. Presumably the main menu settings get saved somewhere that should be safe during a crash; it remembers all other settings so why not this. Could this have something to do with the crashes? Using the default skin. I can’t reproduce the crashing issue so no logs.
During library updates I tend to get a trakt api error message, and that further tries will be suppressed for 30 mins. I don’t use trakt and it’s disabled in the scraper settings (it’s disabled by default even). In my firewall I can see that it is indeed connecting to api.trakt.tv during every library update. What is connecting to trakt and why? And how can I disable it?
Is it possible to disable the bright blue light on the front of the device? It’s distracting. Currently I’ve used a high tech solution in the form of some masking tape…
