https://paste.osmc.tv/iyisoyuged
I keep getting the sad face crash screen whenever I try to play any media. The cause of the problem may be from this post: Speed? - #9 by sam_nazarko I followed those instructions.
Any help would be great, would prefer not to reinstall again.
You seem to be running the jessie-devel repository (which is experimental) You should revert to the stable repository.
jessie-devel
How does one do that? I tried deleting the line and running the apt get stuff again and didn’t work. Thanks
sudo apt-get update sudo apt-get install --reinstall vero3-mediacenter-osmc/jessie
Should do the trick.
Indeed it did. Much appreciated.
Great news!
