After updating my OSMC with:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get autoremove
sudo reboot
All I get a sad face when I boot. A took a look at the logs on http://paste.osmc.io/onenuhalaw but got nowhere. Can anyone tell what’s wrong?
Thanks,
Luis
You need to reinstall, you just hosed your system.
Nah, saw the log… He’s been hosing it for months…
the_bo
#5
Maybe when someone uses apt-get upgrade. It should automatically use dist-upgrade?
Not sure if it’s possible. But would be good.
This is not trivial to do, but we have considered this.
Thanks for the explanation, that was crystal clear.
