On one Pi2 and one PI3 I’m using the HP MCE remote with its USB IR receiver, it works as expected for a few seconds then it gets crazy: the remote events (visible with irw) are duplicated infinitely. Eventually it can stop by itself…
Only workaround is to use a keyboard.
It was not doing that at first, I believe it started 2 releases ago.
