Settings > Interface > Skin > Configure Skin… > Background > “Untick Use Default OSMC Background” > Custom Background Color -> what does it do? I was excpeting that i can Change the Color of the blue Gradient in the Background. But it does nothing.
I have changed the blue backgroung gradient to a yellow gradient. But needed to edit the Textures.xbt.
But with every update i Need to edit the Textures.xbt…
Is there a more convenient way to Change the blue Gradient to a custom Color permanently?
There should be no need to change the textures.xbt. Here the color picker takes immediate effect and works as expected. Could you be so kind as to post a screenshot of your color picker settings after having configured it the way you want and before closing that window again?
Also, the settings of the color picker should normally survive an update.
Add the following line: deb http://apt.osmc.tv stretch-devel main
