Hi all,
I’m currently migrating my setup from a Cubox-I running ArchLinux to RPi3 running OSMC.
As part of that I need to remap a key on my cheap RF remote from KEY_UNKNOWN to F1(not used by any other key). In Arch I did this with a simple hwdb file in /etc/udev/hwdb.d/
followed by systemd-hwdb --update
and all was well.
I’m not able to achieve the same in OSMC though. I did create my file and re-built the hwdb.bin using udevadm hwdb --update
but it’s simply not being applied. What I’ve done so far is
- Created my overrides in
/lib/udev/hwdb.d/
to make sure they would be picked up byudevadm
- Overwritten the hwdb.bin in
/lib/udev
in case OSMC is ignoring my generated one in/etc/udev
- Checked all identifiers to make sure the device was being identified in the same way as on Arch so my rules should apply.
Now I know OSMC and Arch are very different distro’s. Am I missing some small detail on OSMC(debian) that is needed to make my changes stick/apply?
P.S. Why do we not have systemd-hwdb
on OSMC?
