Hello all,
is it possible to add the DCI-P3 colour space (so that instead of REC2020 the DCI-P3 can be used)?
I got a projector which is capable of DCI-P3. So i would use for the my UHD content a DCI-P3 profile (and for the Bluray content also, because the DCI-P3 colour space is bigger than the REC709 used on Bluray).
I would like to set my projector to DCI-P3 and play all files (regardless if it is Bluray content or UHD).
Is this possible?
Yes. It’s possible on Vero and we’ll look into it. I don’t know enough about RPi.
If you are using a Vero, could you post logs with it connected to your projector and let us have the make and model?
Could you give me a quick how to get the log?
Either via Settings -> MyOSMC -> Log Uploader or SSH grab-logs -A
@grahamh sorry for the short delay ![]()
heres the log:
https://paste.osmc.tv/azoyexowuj
Projector is an Epson LS10000
We are not seeing DCI-P3 capability in the EDID. Can you connect Vero direct to the PJ, set it to DCI-P3 mode and grab logs again?
