Life got in the way and I’ve finally gotten around to recabling this (needed help due to the weight of the TV, to get it off the stand). Audio is working as expected by plugging into the AVR directly.
However, with this setup, I don’t seem to be able to get 4k content to play in 4k resolution. CEC is working fine, I should note.
If I plug the Vero V back into the TV, I lose passthrough audio (per the OP), but 4K HLG works as expected.
On the Marantz AVR if I navigate through the menus to Setup > General > Information > Video
- Signal > 1080p:60Hz → 4K30Hz (when I play the 4k video, this changes to 1080p:50Hz → 4K:25Hz; if I go into Kodi Settings > System > Display and set the Resolution to 4k (as a test, as I know it’s better to leave the interface in 1080p), the AVR then shows 4K:24Hz → 4K:24Hz, but then playing the same file it still doesn’t fire up HDR mode on the TV)
Color Space YCbCr 4:4:4 → YCbCr 4:4:4
Pixel Depth 10bits → 8bits
- Monitor
Interface HDMI
Resolutions 480p, 576i/p, 1080i:50/60Hz, 720p:50/60Hz, 1080p:24/25/30/50/60Hz, 4K:24/25/30Hz
Regarding EDID info:
osmc@osmc:/sys/class/amhdmitx/amhdmitx0$ cat config
cur_VIC: 31
cur_video_param->VIC=31
cur_video_param->colordepth: 10bit
para->colorspace: 444
AVIF VIC: 31
VIC: 31 1920x1080p50hz
Colour depth: 10-bit
Colourspace: YUV444
Colour range: limited
EOTF: SDR
YCC colour range: limited
Colorimetry: BT709
PLL clock: 0xdb14049a, Vid clock div 0x000b0000
Aspect ratio: 16:9/full frame
DV type Not DV
audio config: on
audio on/off: on
audio source: I2S
audio type: L-PCM
audio channel num: 2 channels
audio sample rate: 48kHz
audio sample size: MAX
3D config: off
osmc@osmc:/sys/class/amhdmitx/amhdmitx0$ cat edid
Rx Manufacturer Name: MJI
Rx Product Code: 0025
Rx Serial Number: 01010101
Rx Product Name: marantz-AVR
Manufacture Week: 0
Manufacture Year: 2012
Physical size(mm): 1600 x 900
EDID Version: 1.3
EDID block number: 0x1
blk0 chksum: 0x87
Source Physical Address[a.b.c.d]: 2.3.0.0
YCC support 0x03, VIC (native 95):
ColorDeepSupport 0xb8 10/12/16/Y444 1/1/0/1
95 16 31 4 19 5 20 3 2 18 32 33 34 21 93 94 98 99 100 63 64 14 15 30 38 95 94 93 98
Audio {format, channel, freq, cce}
{1, 7, 0x7f, 0x07}
{7, 5, 0x1e, 0xc0}
{2, 5, 0x07, 0x50}
{11, 7, 0x7e, 0x01}
{10, 7, 0x06, 0x00}
{12, 7, 0x7e, 0x00}
Speaker Allocation: 0x5f
Vendor: 0x000c03 (HDMI device)
MaxTMDSClock1 300 MHz
vLatency: Invalid/Unknown
aLatency: Invalid/Unknown
i_vLatency: Invalid/Unknown
i_aLatency: Invalid/Unknown
Colorimetry: 0xc0
SCDC: 0
RR_Cap: 0
LTE_340M_Scramble: 0
DeepColor
checkvalue: 0x87620000
Logs available here: https://paste.osmc.tv/icaqaxoguj
This captures:
- Playing a video 1080p
- Playing a video 4k HLG
- Setting the Kodi resolution to 4k and then playing a 1080p video
- Setting the Kodi resolution to 4k and then playing a 4k HLG video
As a side note, when the Vero V is connected to the AVR and I turn the AVR off and it’s just doing passthrough to the TV, the text in Kodi is sharper. Not sure if that’s a) expected b) related to this issue at all.
