Have been enjoying my vero 4k+ a lot, however recently noticed crackling noises when playing movies. Had my vero 4k+ for over a year and only recently started noticing this.
setup
-Vero 4K+, HDMI to Samsung TV, optical cable to Marantz NR1504 receiver for audio (receiver does not support 4k passthrough to tv hence the two cables used.
-Marantz NR1504 supports DD and DTS, setup with two speakers only (2.0)
-My TV can only pass DD to the receiver. In Theory I could send audio via the TV but that would imply transcoding DTS to DD in order for my tv to pass it back to the receiver. As I have a DTS receiver my first attempt would be to try and fix this
issue
When playing movies I lately noticed a crackling noise on my left speaker only. It starts on playback and is not very loud, I can hear it only if the movie audio isn’t very loud. It is always there as long as playback is ongoing, and stops when I stop playback
-This only happens for DD/DTS movies. Just played a movie with AAC Stereo there is no crackling whatsoever. Same for playing MP3, the audio is fine
-This leads me to assume my cabling is fine (optical cable) and cables to my speakers
-Playing Netflix (app on tv, not via kodi) with DD also works fine so the setup is able to play DD without crackling. Ps4 also plays without noise.
Kodi Settings I recall setting this up using a guide here over a year ago
-Audio output device: AML-M8AUDIO, HDMI
-# of channels: 2.0
-Output config: Best match
-Volume control steps: 60
-Maintain original volume on downmix: on
-Stereo upmix: off
-Include LFE in stereo downmix: 0%
-Boost centre channel when downmixing: 0dB
-Resample quality: Medium
-Treshold for pitch correction: 2
-Keep audio device alive: 2 minutes
-send low volume noise: off
Gui
-Gui sounds: only when playback stopped
-Gui sounds: Kodi UI sounds
Audio passthrough
-Allow passthrough: on
-passthrough output device: (greyed out, same as above A)ML-M8AUDIO, HDMI
-DD (AC3) capable receiver: on
-Enable DD traanscoding: on
-DD plus capable receiver: off
-DTS capable receiver: on
-TrueHD capable receiver: off
-DTS-HD capable receiver: off
So struggling a bit on where to start troubleshooting. Happy to post a log ofcourse but not sure if that would help for crackling audio of if, based on the above, someone could suggest some steps to try and tackle this. It’s very possible I messed up a setting (e.g. don’t understand my output as it doesn’t list SPDIF but recall I had to make a change here as otherwise my tv also gets audio, sends it back to the receiver, overruling the optical lead going in there)
