One of my Vero 4K+ devices is kind of ‘dead’, it starts and after some network and share setup (syslog screen output) flashes by, the screen goes black and the Vero doesn’t respond anymore. SSH is also not working.
So, I decided to reinstall OSMC. but with the image install tool I get stuck as well. Whether I download the image file or let it download by the installer program, either way I almost immediately get the following error: “An error occured extracting the archive! Please consult the logfile”. No logfile to be found…
And the manually downloaded image could be extracted with 7-zip just fine.
So, I am stuck with a dead device and no way to reinstall it…
Which OS are you using with the installer?
If the installer is not working you could always write the Image with any image writter (Rufus, Win32diskimager, Etcher, Unetbootin).
Generally it seems restoring via SD Cards is more successful than via USB Drive
Did you check your user folder?
Please provide the information @fzinken has requested so we can get this solved promptly for you
OK, didn’t expect the log file to be in directory higher up…
The log:
Sun 25. Aug 10:38:33 2019 OSMC Installer running on Windows
Sun 25. Aug 10:38:33 2019 Detected locale as en_NL
Sun 25. Aug 10:38:33 2019 Attempting to load translation for locale en_NL
Sun 25. Aug 10:38:33 2019 Could not load translation!
Sun 25. Aug 10:38:33 2019 Resolving a mirror
Sun 25. Aug 10:38:33 2019 Resolved mirror to http://ftp.acc.umu.se/mirror/osmc.tv/osmc/download/
Sun 25. Aug 10:38:33 2019 Enumerating supported devices
Sun 25. Aug 10:38:33 2019 Added the following devices
Sun 25. Aug 10:38:33 2019 Vero 4K / 4K+
Sun 25. Aug 10:38:33 2019 Vero 2
Sun 25. Aug 10:38:33 2019 Raspberry Pi 1 / Zero
Sun 25. Aug 10:38:33 2019 Raspberry Pi 2 / 3
Sun 25. Aug 10:38:33 2019 Apple TV
Sun 25. Aug 10:38:33 2019 Checking for updates
Sun 25. Aug 10:38:33 2019 Checking for updates by downloading http://ftp.acc.umu.se/mirror/osmc.tv/osmc/download//installers/latest_windows
Sun 25. Aug 10:38:33 2019 Acquired mirror file
Sun 25. Aug 10:38:33 2019 No new update is available
Sun 25. Aug 10:39:01 2019 The user has selected English as their language
Sun 25. Aug 10:39:01 2019 The user has selected Vero 4K / 4K+ as their device
Sun 25. Aug 10:39:01 2019 Attempting to download device versions file http://ftp.acc.umu.se/mirror/osmc.tv/osmc/download/installers/versions_VERO3
Sun 25. Aug 10:39:01 2019 Found a build called 2019.07-1
Sun 25. Aug 10:39:01 2019 Found a build called 2019.06-1
Sun 25. Aug 10:39:01 2019 Found a build called 2019.05-1
Sun 25. Aug 10:39:01 2019 Found a build called 2019.04-1
Sun 25. Aug 10:39:01 2019 Found a build called 2018.12-1
Sun 25. Aug 10:39:01 2019 Found a build called 2018.10-1
Sun 25. Aug 10:39:01 2019 Found a build called 2018.08-1
Sun 25. Aug 10:39:01 2019 Found a build called 2018.07-1
Sun 25. Aug 10:39:13 2019 The user has selected an online image for Vero 4K / 4K+ with build URL : http://ftp.acc.umu.se/mirror/osmc.tv/osmc/download/installers/diskimages/OSMC_TGT_vero3_20190808.img.gz
Sun 25. Aug 10:39:13 2019 Disabling NFS install for device Vero 4K / 4K+ as it does not support it
Sun 25. Aug 10:39:13 2019 Disabling USB install for device Vero 4K / 4K+ as it does not support it
Sun 25. Aug 10:39:13 2019 Disabling SD install for device Vero 4K / 4K+ as it does not support it
Sun 25. Aug 10:39:13 2019 Disabling internal install for device Vero 4K / 4K+ as it does not support it
Sun 25. Aug 10:39:13 2019 This device does not support preseeding at all.
Sun 25. Aug 10:39:13 2019 Installing usbit32 imaging binary to temporary path
Sun 25. Aug 10:39:13 2019 Installing empty boot sector to temporary path
Sun 25. Aug 10:39:13 2019 Installation was successful
Sun 25. Aug 10:39:13 2019 Enumerating imageable devices for Windows
Sun 25. Aug 10:39:13 2019 New disk device entry created with entry point D:\, 58656MB free space and label
Sun 25. Aug 10:39:30 2019 Device selected: 2 D:\ 58656MB
Sun 25. Aug 10:39:38 2019 EULA has been accepted
Sun 25. Aug 10:39:38 2019 Downloading http://ftp.acc.umu.se/mirror/osmc.tv/osmc/download/installers/diskimages/OSMC_TGT_vero3_20190808.img.gz
Sun 25. Aug 10:39:38 2019 Download successful
Sun 25. Aug 10:39:38 2019 Extracting C:/Users/Ron/OSMC_TGT_vero3_20190808.img.gz
Sun 25. Aug 10:41:02 2019 OSMC Installer running on Windows
Sun 25. Aug 10:41:02 2019 Detected locale as en_NL
Sun 25. Aug 10:41:02 2019 Attempting to load translation for locale en_NL
Sun 25. Aug 10:41:02 2019 Could not load translation!
Sun 25. Aug 10:41:02 2019 Resolving a mirror
Sun 25. Aug 10:41:03 2019 Resolved mirror to http://ftp.acc.umu.se/mirror/osmc.tv/osmc/download/
Sun 25. Aug 10:41:03 2019 Enumerating supported devices
Sun 25. Aug 10:41:03 2019 Added the following devices
Sun 25. Aug 10:41:03 2019 Vero 4K / 4K+
Sun 25. Aug 10:41:03 2019 Vero 2
Sun 25. Aug 10:41:03 2019 Raspberry Pi 1 / Zero
Sun 25. Aug 10:41:03 2019 Raspberry Pi 2 / 3
Sun 25. Aug 10:41:03 2019 Apple TV
Sun 25. Aug 10:41:03 2019 Checking for updates
Sun 25. Aug 10:41:03 2019 Checking for updates by downloading http://ftp.acc.umu.se/mirror/osmc.tv/osmc/download//installers/latest_windows
Sun 25. Aug 10:41:03 2019 Acquired mirror file
Sun 25. Aug 10:41:03 2019 No new update is available
Sun 25. Aug 10:41:21 2019 The user has selected English as their language
Sun 25. Aug 10:41:21 2019 The user has selected Vero 4K / 4K+ as their device
Sun 25. Aug 10:41:21 2019 Attempting to download device versions file http://ftp.acc.umu.se/mirror/osmc.tv/osmc/download/installers/versions_VERO3
Sun 25. Aug 10:41:21 2019 Found a build called 2019.07-1
Sun 25. Aug 10:41:21 2019 Found a build called 2019.06-1
Sun 25. Aug 10:41:21 2019 Found a build called 2019.05-1
Sun 25. Aug 10:41:21 2019 Found a build called 2019.04-1
Sun 25. Aug 10:41:21 2019 Found a build called 2018.12-1
Sun 25. Aug 10:41:21 2019 Found a build called 2018.10-1
Sun 25. Aug 10:41:21 2019 Found a build called 2018.08-1
Sun 25. Aug 10:41:21 2019 Found a build called 2018.07-1
Sun 25. Aug 10:41:25 2019 The user has selected an online image for Vero 4K / 4K+ with build URL : http://ftp.acc.umu.se/mirror/osmc.tv/osmc/download/installers/diskimages/OSMC_TGT_vero3_20190808.img.gz
Sun 25. Aug 10:41:25 2019 Disabling NFS install for device Vero 4K / 4K+ as it does not support it
Sun 25. Aug 10:41:25 2019 Disabling USB install for device Vero 4K / 4K+ as it does not support it
Sun 25. Aug 10:41:25 2019 Disabling SD install for device Vero 4K / 4K+ as it does not support it
Sun 25. Aug 10:41:25 2019 Disabling internal install for device Vero 4K / 4K+ as it does not support it
Sun 25. Aug 10:41:25 2019 This device does not support preseeding at all.
Sun 25. Aug 10:41:25 2019 Installing usbit32 imaging binary to temporary path
Sun 25. Aug 10:41:25 2019 Installing empty boot sector to temporary path
Sun 25. Aug 10:41:25 2019 Installation was successful
Sun 25. Aug 10:41:25 2019 Enumerating imageable devices for Windows
Sun 25. Aug 10:41:25 2019 New disk device entry created with entry point D:\, 58656MB free space and label
Sun 25. Aug 10:41:30 2019 Device selected: 2 D:\ 58656MB
Sun 25. Aug 10:41:33 2019 EULA has been accepted
Sun 25. Aug 10:41:33 2019 Downloading http://ftp.acc.umu.se/mirror/osmc.tv/osmc/download/installers/diskimages/OSMC_TGT_vero3_20190808.img.gz
Sun 25. Aug 10:41:37 2019 Download successful
Sun 25. Aug 10:41:37 2019 Extracting C:/Users/Ron/OSMC_TGT_vero3_20190808.img.gz
Sun 25. Aug 10:44:13 2019 OSMC Installer running on Windows
Sun 25. Aug 10:44:13 2019 Detected locale as en_NL
Sun 25. Aug 10:44:13 2019 Attempting to load translation for locale en_NL
Sun 25. Aug 10:44:13 2019 Could not load translation!
Sun 25. Aug 10:44:13 2019 Resolving a mirror
Sun 25. Aug 10:44:13 2019 Resolved mirror to http://mirrors.dotsrc.org/osmc/osmc/download/
Sun 25. Aug 10:44:13 2019 Enumerating supported devices
Sun 25. Aug 10:44:13 2019 Added the following devices
Sun 25. Aug 10:44:13 2019 Vero 4K / 4K+
Sun 25. Aug 10:44:13 2019 Vero 2
Sun 25. Aug 10:44:13 2019 Raspberry Pi 1 / Zero
Sun 25. Aug 10:44:13 2019 Raspberry Pi 2 / 3
Sun 25. Aug 10:44:13 2019 Apple TV
Sun 25. Aug 10:44:13 2019 Checking for updates
Sun 25. Aug 10:44:13 2019 Checking for updates by downloading http://mirrors.dotsrc.org/osmc/osmc/download//installers/latest_windows
Sun 25. Aug 10:44:13 2019 Acquired mirror file
Sun 25. Aug 10:44:13 2019 No new update is available
Sun 25. Aug 10:44:25 2019 The user has selected English as their language
Sun 25. Aug 10:44:25 2019 The user has selected Vero 4K / 4K+ as their device
Sun 25. Aug 10:44:25 2019 Attempting to download device versions file http://mirrors.dotsrc.org/osmc/osmc/download/installers/versions_VERO3
Sun 25. Aug 10:44:25 2019 Found a build called 2019.07-1
Sun 25. Aug 10:44:25 2019 Found a build called 2019.06-1
Sun 25. Aug 10:44:25 2019 Found a build called 2019.05-1
Sun 25. Aug 10:44:25 2019 Found a build called 2019.04-1
Sun 25. Aug 10:44:25 2019 Found a build called 2018.12-1
Sun 25. Aug 10:44:25 2019 Found a build called 2018.10-1
Sun 25. Aug 10:44:25 2019 Found a build called 2018.08-1
Sun 25. Aug 10:44:25 2019 Found a build called 2018.07-1
Sun 25. Aug 10:45:57 2019 The user has selected a local image for Vero 4K / 4K+ with file location: file:///C:/Users/Ron/Downloads/OSMC_TGT_vero3_20190808.img.gz
Sun 25. Aug 10:45:57 2019 Disabling NFS install for device Vero 4K / 4K+ as it does not support it
Sun 25. Aug 10:45:57 2019 Disabling USB install for device Vero 4K / 4K+ as it does not support it
Sun 25. Aug 10:45:57 2019 Disabling SD install for device Vero 4K / 4K+ as it does not support it
Sun 25. Aug 10:45:57 2019 Disabling internal install for device Vero 4K / 4K+ as it does not support it
Sun 25. Aug 10:45:57 2019 This device does not support preseeding at all.
Sun 25. Aug 10:45:57 2019 Installing usbit32 imaging binary to temporary path
Sun 25. Aug 10:45:57 2019 Installing empty boot sector to temporary path
Sun 25. Aug 10:45:57 2019 Installation was successful
Sun 25. Aug 10:45:57 2019 Enumerating imageable devices for Windows
Sun 25. Aug 10:45:57 2019 New disk device entry created with entry point D:\, 58656MB free space and label
Sun 25. Aug 10:46:00 2019 Installing usbit32 imaging binary to temporary path
Sun 25. Aug 10:46:00 2019 Installing empty boot sector to temporary path
Sun 25. Aug 10:46:00 2019 Installation was successful
Sun 25. Aug 10:46:00 2019 Enumerating imageable devices for Windows
Sun 25. Aug 10:46:00 2019 New disk device entry created with entry point D:\, 58656MB free space and label
Sun 25. Aug 10:46:05 2019 Device selected: 2 D:\ 58656MB
Sun 25. Aug 10:46:08 2019 EULA has been accepted
Sun 25. Aug 10:46:08 2019 Extracting C:/Users/Ron/Downloads/OSMC_TGT_vero3_20190808.img.gz
Sun 25. Aug 10:46:08 2019 Could not open target file C:/Users/Ron/Downloads/OSMC_TGT_vero3_20190808.img
Sun 25. Aug 10:46:08 2019 Error string was Access is denied.
OS is Windows 10, 1903 to be exact.
And with the USB stick created with Rufus I was able to reinstall the Vero.
You need to run the installer as an administrator
I did (Right-click, Run as Administrator) ;o)
Not sure then. Maybe some interaction with AV software
In my case, Symantec Endpoint Protection needs to be disabled before running the installer, otherwise I get the same error.
Haven’t tried, but just using default Windows Defender stuff and configuration.
